Old 12-13-2014, 06:20 PM
claycookiemonster's Avatar
claycookiemonster claycookiemonster is offline
Default Squeezer sprung a leak
So, my pneumatic squeezer fell off my workbench. Fortunately it didn't "clang" onto the bare concrete floor, it thumped onto some rubber padding I had put down. Nevertheless, it immediately began leaking air. The leak comes from the valve/plunger (adjacent to the air input) that is depressed by the trigger. It still works and the leak stops when the trigger is depressed and the squeezer extends, but the plunger is very slow to retract and the air leak begins immediately after releasing the trigger.
It's a generic Avery squeezer, about 12 years old and only recently put back into service after 5 years sitting in the drawer. It doesn't look very easy to disassemble or open, so...?
Anyone with air tool experience have any idea what's going on here? It feels like it's still usable, but clearly something happened when this hit the mat.
Clay "Cookiemonster" Cook
USAF: T-38, F-111F
American Airlines: 727, MD80, 757, 767, 737
RV8 #81751 project sold
RV8 #81651 project acquired
https://theonceandfutureflyer.wordpress.com/
Donations up to date thru December 2015
"...serenity...courage...and wisdom..."
Old 12-13-2014, 06:32 PM
g zero g zero is offline
Default Squeezer
Mine started leaking after I loaned it out . I took the area you are speaking about apart and replaced the o-rings . I have a tray of o-rings and find them very handi for things like this .
Tom
Rv8
N 666 TA
First Flight 2-3-2015 🚀
2017 donation paid
Old 12-13-2014, 09:20 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Send it home to Bob Avery - it will come back as good as new in about a week and the cost is pretty reasonable when you amortize it over those twelve years....
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 12-14-2014, 12:13 PM
Smilin' Jack Smilin' Jack is offline
Amen to what Paul said, I borrowed a squeezer from a builder who was finished and it barely worked. one call to Bob Avery and it was fixed, painted, new decals and a replaced parts bag showing every thing he replaced. I used to to build my 7 and now others are using it.
Smilin' Jack
Smilin' Jack & Anita Hunt
N507H RV7, KJZP Jasper, GA
EAA690
APRS/ WB4JKY
Retired Corporate Pilot CFI-AI, MEL
CE500, LRJT, HS25, C650, SBJT, CL60
Hunt Aviation, LLC.
Pilot Service, IPC's Biennials.
Comm Glider
