Go Back   VAF Forums > RV Firewall Forward Section > Propellers
Old 12-13-2014, 07:44 AM
pilot2512 pilot2512 is offline
Default prop bolts 3/8 or 7/16. does it matter?
I got a used engine that has 7/16 prop bolts. I'm planning on a Catto prop. I know the nuts can be changed out, but are there any advantages to moving up to 3/8"?
Jay
RV-9A
Empennage complete.
Wings complete.
Fuselage in progress
Wiring in progress
2020 Donation made!
Old 12-13-2014, 08:16 AM
Ron RV8's Avatar
Ron RV8 Ron RV8 is offline
Default moving up to 3/8?
3/8 is smaller than 7/16... Or did you mean it the other way?
Ron Townson
Okanagan Valley BC, Canada
RV-8 Completed Dec 2013
Membership renewed Sept 8, 2019
Old 12-13-2014, 08:19 AM
terry.mortimore terry.mortimore is offline
Default Prop bolts size
Hi Jay, check your tape measure. 7/16" bolts are larger than 3/8".
I have the smaller 3/8" bolts and I'm wondering if they will be suitable. I"ll be using a 4 inch extension with a ground adjustable Sennsenich prop. I haven't asked the question yet, but it's getting close.
If you still want the 3/8" I'll trade ya
Terry
Old 12-13-2014, 08:53 AM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
you will want to stay with the larger 7/16" bolts for many reasons.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 12-13-2014, 08:57 AM
AX-O's Avatar
AX-O AX-O is offline
at the end of the day it does not matter (as long as the horse power has not been dramatically upgraded). You will need a prop extension. Get it from Saber.
One side of the prop extension will have the engine bolts, the other side will have the prop bolts.
I have a 320 with 3/8 on the engine and 7/16 on the prop, I have a 7/16 on the engine and 7/16 on the prop. I just ordered one with 1/2 on the engine side and 7/16 on the prop side.
Keep what you got.
Edit: posted at the same time as Reiley.
Axel
RV-4 fastback thread and Pics
VAF 2020 paid VAF 704
Old 12-13-2014, 01:51 PM
Yes, 3/8 is smaller than 7/16. First cup of coffee not in affect when I started the thread. Lol. Thanks for the replies
Jay
RV-9A
Empennage complete.
Wings complete.
Wiring in progress
2020 Donation made!
Old 12-14-2014, 08:33 AM
smokyray's Avatar
smokyray smokyray is offline
Default Size matters...
Jay,
If you bolt on a wood prop, the 7/16" bolts hold torque easily to 25 hours, the 3/8" not so much. When I built my 4 it had a Sterba woodie and 3/8" bolts. I checked my prop nuts every 10 hours, more often than not they weren't up to 22ft lbs. After switching to 7/16" bolts, the problem went away. 0-360"s use 7/16" bolts (or 1/2), size does matter!
Since Craig's props don't "swell" like wood props, 3/8" prop bolts for an 0-320 would be ok. However, the first Catto RV prop was on my 0-320 powered RV4 with 7/16" bolts!
I know what I would do...
V/R
Smokey
Old 12-14-2014, 12:24 PM
Originally Posted by smokyray View Post
0-360"s use 7/16" bolts, size does matter!
SmokyRay... I'm pretty sure 360's use 1/2" bolts. Well, at least all the ones I've seen have used 1/2" bolts.
Reiley
VAF# 671
Friend of the RV-1
Old 12-14-2014, 05:19 PM
smokyray's Avatar
Default Absolutely!
Originally Posted by LifeofReiley View Post
SmokyRay... I'm pretty sure 360's use 1/2" bolts. We, at least all the ones I've seen have used 1/2" bolts.
Reiley,
You are correct sir, the 0-360 flange bolts are 1/2". However, many FP RV cowlings require an extension which attaches to the flange with 1/2" bolts and 7/16" or 1/2" through the prop. Craig Catto's and many other prop makers allow both options.
I opted for the 1/2" flange/Saber extension bolts, 7/16" prop bolts on my RVX 0-360J2A
V/R
Smokey
