Old 10-25-2006, 07:50 AM
rock5219 rock5219 is offline
Default Rear Canopy Intallation RV9A Tipup
I am ready to install the rear canopy. My turtledeck was riveted on many months ago. Now I read that it should be removed for fitting and installing the rear canopy. Can the rear canopy be fitted and installed properly, WITHOUT drilling out the 200+ rivets? Randy
Old 10-25-2006, 04:25 PM
robertahegy's Avatar
robertahegy robertahegy is offline
Moderator/Tech Counselor
You should not have any problems fitting the rear window. I removed mine several times for finishing and painting. It should slide in between the roll bar and the skin.
Roberta
Roberta Hegy
Built/Flew an RV-7A
Air Troy Estates, East Troy, WI
Ford Expedition and TRICE "Q"
Built Glen L "ZIP" Classic Outboard Runabout and Super Spartan Hydroplane
Glen L Torpedo
