Old 10-25-2006, 06:46 AM
BlackRV7's Avatar
BlackRV7 BlackRV7 is offline
Default Impulse Mag...Top/Bottom/Both
OK, I've seen/heard/read/dreamed (stretching it there:-) about putting the impulse mag harness on the top plugs only with the right mag (looking at it from the the rear of the engine) on the bottom only. Obviously, the harnesses are marked T4, T2, B3, B1 and B4, B2, T3, T1. Put them is this orientation, the arguement is you get a more consistantly close drop between left and right. The assumption; the bottom plugs are more likely to get oil fouled due to gravity.
Current pros, cons to harness indicated orientation or top/bottom only???
Just food for thought after looking at a one mag/electronic setup where the builder did the electronic on top plugs only and mag on bottom plugs only.
Dana Overall
Richmond, KY i39
http://www.DanaOverallCPA.com
Repeat offender, RV-10 emp
Builder/former owner, RV-7, "Black Magic" Flying
http://www.youtube.com/watch?v=MMi05-WU2D0#GU5U2spHI_4
VAF #993
Old 10-25-2006, 06:00 PM
BlackRV7's Avatar
Another quick question. Does anyone have a shot of any super special mag harness passthroughs (rear baffle), such as any from hot rod shops? I'm looking for something other than a hole and RTV.
Dana Overall
Richmond, KY i39
VAF #993
Old 10-26-2006, 04:54 PM
akarmy's Avatar
akarmy akarmy is offline
Here are the versions I used to pass the wires through...
Baffle Seals from Aircraft Spruce
Andy Karmy
Covington WA
RV-8 - Flying!
RV-9A - sold
Dec 2019 Paid
Old 10-26-2006, 06:47 PM
az_gila's Avatar
az_gila az_gila is offline
Exclamation Color
Yes... but my two-hole ones were delivered in a pretty baby blue color....
gil in Tucson
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
