Old 12-08-2014, 05:34 PM
lr172 lr172 is offline
Default Fuel / Exhaust Spacing Question
I am working on FWF on my 6A with O-320. I am using a Tee at the carb inlet and the end connection is getting close to the exhaust. At the first pass, my braided hose/connector is a bit over an inch from the exhaust and it seemed too close. i can put in a 45* elbow and get it to about 3".
I was wondering the general consensus on what distance is considered safe. I considered making a heat shield as well. The fuel line will have fire shield.
Thanks for your guidance here.
Larry
Old 12-08-2014, 06:15 PM
DanH's Avatar
DanH DanH is offline
Larry, there is no minimum distance, but there are maximum temperatures. Your goal is to keep the fuel less than 130~140F ballpark. Don't settle for less than a maximum possible distance. If you can get 3" from a hot object by using another fitting, do it. If something else will move it out to 5", do that too.
Dan Horton
RV-8 SS
Barrett IO-390
Old 12-08-2014, 11:08 PM
Michael Burbidge Michael Burbidge is offline
Default My solution
Larry,
Check out this thread for the solution I arrived at. I did not like the routing suggested by the plans and so had a custom line made by ts flight lines.
http://www.vansairforce.com/communit...d.php?t=100419
Michael
Michael Burbidge
Sammamish, WA
RV-14A Empennage
RV-9A Flying?340 hours!
Last Donation: December 2019
Old 12-09-2014, 10:11 AM
airguy's Avatar
airguy airguy is offline
Also, it would be a good idea to put a heat shield on the exhaust line where the fuel lines make their closest approach.
http://vansaircraft.com/cgi-bin/stor...t=heat-shields
