FWF & Oil temp sender location
A few good questions for the engine gurus out there. A little background - Lyc O-320 "E" series with fresh professional rebuild, and I've never hacked a Lyc before (but done plenty of VW's).
#1: Which plug does the oil temp sender fit into? Looking forward I see one above and to the left of the oil filter, and one almost directly below the filter. Next question: Which ports are best for the primer? I have one above the intake port and one down on the side. Last: I have a need for manifold pressure to the EMag. It requires an small hose (1/8" I think) from the port to the mag. What AN fitting do I use to get the hose to the mag?
Thanks for all the help and don't forget to send Doug some money for his childrens' education.
Kelly Patterson
200 hours
RV-6A N716K
Parker, CO
