Old 12-05-2014, 08:50 AM
Guilhermepilot's Avatar
Guilhermepilot Guilhermepilot is offline
Default Throttle mix cables lenght
Engine in its nest it is time to assemble many things
I have a stock vans mix/throttle cables for my superior vertical Induction IO360 (45)
As I am in Brazil things can get complicated if I need to order parts in terms of time and cost, question is gonna fit?
Thanks captains
Guilherme Plassmann (Brazil)
RV7A (Mr Flame) slow kit S/N 74285 Finished 04/14/15😀😀😀😀flying
G3X
Superior IO360
Sterba prop
TSFlightlines hoses
LR30,PRM1,C560,C510S,HS125,B350 FAA/ANAC Pilot
Donation made 2016
Old 12-05-2014, 02:21 PM
Rupester Rupester is offline
Default Hard to say ...
Part of the mixture cable question is the routing you use thru the firewall AND which carb or injection servo you have. I tried routing my mix cable in the spot shown on Vans plans (to a Silverhawk servo, Superior IO-320, vertical induction) and it did not reach. In fact, the longest mixture cable Vans offered (at that time) wouldn't reach. I ended up cutting another hole in the firewall for a more direct route.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 12-07-2014, 12:10 PM
Thanks Rupester
I will try to figure it out
G3X
Superior IO360
Sterba prop
TSFlightlines hoses
Donation made 2016
