Originally Posted by ccsmith51
Hi Chris,
It helps but I already have that and it still confuses me (which isn't hard).
For example we have:
O-320-A1A
150 hp (112 kW) at 2700 rpm, Minimum fuel grade 80/87 avgas, compression ratio 7.00:1. Provisions for a controllable pitch propeller and 25-degree spark advance.
ok and then we have:
O-320-A2A
150 hp (112 kW) at 2700 rpm, Minimum fuel grade 80/87 avgas, compression ratio 7.00:1. Same as A1A but with fixed pitch propeller.
But that doesn't tell me whether or not the crank is hollow. In what way is the A2A fixed pitch?
no plumbing?
solid crank?
Both?
Or take this example:
O-320-B2A
160 hp (119 kW) at 2700 rpm, Minimum fuel grade 100/130 or 91/96 avgas, compression ratio 8.50:1. Same as B1A but with fixed pitch propeller provisions.
What are those "provisions"? Is that word an indicator that the engine is easily converted?
thanks
