Old 12-04-2014, 07:30 AM
Saville's Avatar
Saville Saville is offline
Default O320-E2A converted to C/S = Problems?
Hi all!
I'm looking at an RV-4 (to buy) which sports an O-320 E2A. The owner says the engine was converted, by a previous owner, to a Constant Speed prop engine by, he believes, replacing the crank with a "hollow crank".
Also the 7:1 compression ratio was boosted to 8.5 via higher compression pistons.
Does anyone know of serious problems that occur when one converts an E2A in this way?
thanks!
Old 12-04-2014, 08:55 AM
mahlon_r mahlon_r is offline
O-320-E2A at 160HP and those pistons is really an O-320-D2A. The regular O-320-E2A crankshaft and front bearing setup is constant speed capable. So all he really did was add a prop gov drive, CS prop mounting dowels and CS prop plumbing to a O-320-D2A. Which is not going to present any problem as far as the engine or its operation is concerned.
Merry Christmas,
Mahlon
"The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at your own risk."
Old 12-04-2014, 09:01 AM
Saville's Avatar
Merry Christmas,
Mahlon
Is it correct to say then, that an E2A is the same as a D2a except the pistons?
Thank you Mahlon and Merry Christmas to you.
Old 12-04-2014, 09:18 AM
Low Pass's Avatar
Low Pass Low Pass is offline
I flew a converted -E2A with a Hartzell CS prop for 13-14 yrs with zero problems. Had higher compression (160-hp) pistons and pins too.
Old 12-04-2014, 01:28 PM
Saville's Avatar
Mahlon
So how does one figure out which O-320's are hollow cranked and have the bearing setup for C/S and which cannot be converted?
thanks
Old 12-04-2014, 01:40 PM
jrs14855 jrs14855 is offline
Default Engines
320E2D, E3G, E2H, E3D and E3H were originally configured for 0 235 front main bearing. E2H and E3H are not listed for any production aircraft.
Old 12-04-2014, 02:52 PM
Saville's Avatar
Is there a document somwhere that lists all the Lycoming engines and the bearings they have and the cranks they have?
thanks
Old 12-04-2014, 05:10 PM
Default Bearings
I cross referenced the parts book for the 0 235 bearings. This is only and E series issue and only the ones I listed have the 0 235 bearings. It is easy to pick out in the parts book because the 0 235 nose bearing is four piece vs two piece on all others.
Old 12-04-2014, 05:20 PM
Saville's Avatar
Is this parts book readily available? Can you supply a name and/or ID number? I'd really like to get a reference for things like this.
thanks!
Old 12-04-2014, 05:34 PM
Default parts manual
They are available from Lycoming or Lycoming dealer/distributor. Very pricey.
