Old 12-03-2014, 08:15 AM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default Silicone baffle adhesive ???
Can anyone advise an effective adhesive for silicone baffle strip from ACS ? I have high temp red silicone to seal aluminum baffle on the engine, but not ready to open it yet for a test on silicone. Thanks in advance.
Larry DeCamp
RV-3B flying w/7:1 0320 / carb / Pmags / Catto 3b / digital steam
RV-4 fastback w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
Old 12-03-2014, 08:57 AM
flyingriki's Avatar
flyingriki flyingriki is offline
I tested several silicones on pairs of baffle scraps and found a pure clear I have was the strongest. I'll get you a part number later. Red didn't do that well, a black I got for sealing baffles to the engine case did better the clear scraps are still stuck together. The rest I pulled apart with varying degrees of ease.
Old 12-06-2014, 09:37 PM
flyingriki's Avatar
The good clear is Dow 732 or P/N 09-27800
The good black is Permatex Ultra Black.
Old 12-07-2014, 09:27 AM
esco esco is offline
Default Interesting sealants
Dow has a number of sealants https://www.dowcorning.com/content/p...it/80-3258.pdf:
730 temp range is -85 to 500/-65 to 260 (F/C)
732 temp range is -76 to 350 ("intermittent" 400)/-60 to 177 (204)
736 Heat Resistant Sealant range is -85 to 500 (599)/-65 to 260 (315)
______
VAF dues paid though exempt
RV-9A sold (I miss that bird!)
RV10 sold (miss that one too!)
RV-14A build underway
