Old 11-30-2014, 10:06 PM
lr172 lr172 is offline
Default Need help finding alternator that fits
I have purchased the ND 35A alternator(14184) and Van's bracket for my RV-6A (IFR equipped). However, I started adding up my electrical requirements and it just won't work. My standard load is 20 amps, which is fine. Once I add in 10A for Pitot Heat, 7A for Nav lights, 8A for Landing light, 5A for seat heaters, etc. I could end up using the battery reserve more than I like for IFR conditions. With the field current, I bet I can't get more than 30 net amps from this alternator and don't like the reliability running it near capacity most times.
I purchased an ND 14158 altterator that is 50 amps and also rotates CCW. However, the the mounting ears are not consistent with the 14184. They are wider apart and the front ear is 1/8" further from the pulley. I cannot use the van's bracket without modification. I tried to use my old generator bracket and that would have worked if the front ear wasn't 1/8" farther from the belt center line. The pulleys are so close together that 1/8" is too much to accept without a lot of belt wear.
My research indicated that several people here have used the larger ND alternators on the Van's mount. I found a 14131 alternator (45A) that appears to fit the civic that the 14184 came from (the 14158 came from an accord.). Does anyone know if this will fit? Any other recommendations?
I appreciate your assistance.
Larry
Old 11-30-2014, 10:10 PM
PCHunt PCHunt is online now
Depending on the measurements, I have had success with shimming the main mount bolts with washers to align the alternator pulley with the flywheel pulley.
Dunno if this will work in your situation.
Pete Hunt, [San Diego] VAF #1069
RV-6, RV-6A, T-6G
ATP, CFII, A&P
2020 Donation+, Gladly Sent
Old 12-01-2014, 08:21 AM
I wish! On the generator mount, the config on the proper side of the ear leaves me 1/8" forward (need to remove, not shim). If I flip the alternator to the back of the ear, I lose an 1" of clearance due to the cylinder interference and feel that I will not have enough belt adjustment room without hitting the cowl.
I have been contemplating building up the ear of the generator mount with welding rod and re-machining. However, I have no mill and it is not easy with sanding gear. It is my last resort.
Similar issue on the Van's mount. As I a writing this, I am thinking that I'll just bite the bullet and weld. As I look at it, I may be able to weld up the vans' mount without machining.
Larry
Old 12-01-2014, 10:09 AM
mike647m mike647m is offline
Why not just go with the Plane Power 60 amp experimental?
Old 12-01-2014, 10:57 AM
ACS sells a universal bracket for boss-mount alternators. Has slots for the mounting bolts and is blank for the alternator bolt. Worked fine for me.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
Old 12-01-2014, 11:44 AM
Ralph Inkster Ralph Inkster is offline
Note that not all ND alternators are the same wiring wise, especially Hondas.
If you are following the generic (Vans, PlanePower etc) schematic for the 'sense' lead for running an indicator light, late model Honda alternators use this lead for a different purpose (zero to 5volt) and if you hook a 12volt light to it the alternator will go into an overcharge state & fry shortly after. Check your car alternators specific schematic to be sure.
Ralph
built a few RVs, rebuilt a few more, hot rodded some, & maintained/updated a bunch more
Old 12-01-2014, 01:14 PM
Unfortunately I do not have the boss. It is the style that uses 3 case bolts.
Larry
Old 12-01-2014, 01:15 PM
Thanks for the heads up. I am using externally regulated versions of the ND alternator.
Larry
Old 12-01-2014, 01:47 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Default Here you go...
Both internal and external regulated kits, your choice NEW.
http://www.airtecinc.us/aircraft/index.html
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
