  #11
Old 12-09-2014, 07:01 PM
jcaplins's Avatar
jcaplins jcaplins is online now
Default fixed?
Well, I'll just have to put this in the "What the H3LL?" folder.
After swapping various things to various ports and verifying everything is OK, and all setup menus look OK.... I connected a test lead from the transponder case to ground.
It worked. No more red X and there is serial communication.
Powered it off, removed the test lead, powered it back on..... still works. WTH?
Even before connecting a test lead from the case to ground, I had good continuity. So, I don't know. I'm moving on.
Jeff Caplins
California
RV7 N76CX
(started: Feb 2002 --> Completed: May 2016)
Old 12-09-2014, 07:34 PM
Caummisar's Avatar
Caummisar Caummisar is offline
Default Recycled Electrons
That will teach you to not use sub standard aftermarket low grade non-mill spec recycled electrons!!
VAF# 835
RV-7A- Instrument Panel/FWF/Engine Mounted
Slow build --- ALL THE WAY
Victim of SB-632-B
2020 Dues Paid
Old 12-09-2014, 10:31 PM
jcaplins's Avatar
They were metric electrons; maybe that was the problem?
Jeff Caplins
California
RV7 N76CX
Old 12-16-2014, 03:10 AM
pujol's Avatar
pujol pujol is offline
I have the transponder Trig TT22 and I tried to connect it on the skyview but it does't work.
I called Trig support who confirmed me that it is not possible.
It's not the same software between both units.
Either SV-261 with Skyview, or Trig TT22 with his panel controller.
