Old 11-29-2014, 05:27 PM
Dean Pichon Dean Pichon is offline
Default Anyone with experience using "old" polysulfide?
I have a partial can of polysulfide that, according to the label, expired in June of 2013. I would like to use it to re-seal an access panel on my fuel tank. Does anyone have any experience, good or bad, with using out-of-date polysulfide? I plan to make a test batch to confirm that it, at least, appears to cure, but would like to hear about any real experiences.
Thanks in advance for the help.
Dean
Old 11-29-2014, 05:51 PM
Bevan Bevan is offline
I keep it in the fridge (warmed to room temp before use cause it's too thick to mix) with good results sealing the windows and firewall. The left overs were left to cure in a blob and all cured as per normal. It was at least 6 years old. YMMV
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
longline longline is offline
Default No worries
Dean I do not know what others have experienced, but I have used expired sealant to good effect. It appears to take longer to cure, but cure it did. My batch was B-2 and had no special care, it just sat on a shelf for several years. These days I throw "proseal" into the refrigerator, it keeps nicely.
