Old 11-24-2014, 01:47 PM
AndyRV7's Avatar
AndyRV7 AndyRV7 is offline
Default Maintenance Entry?
Hi, I rebuilt the Matco cylinders in my RV-7 over the weekend with the help of an A&P. Do I need to make an entry in the aircraft logs for this work?
Thanks! Andy
Old 11-24-2014, 01:57 PM
DaveO DaveO is offline
I would think that you should. I expect that someone who follows you in ownership would want to know the work you did on the plane. Plus, by having it logged would give some creditability to the value of your plane.
Remember to log it back to flying status.
Dave
Old 11-24-2014, 02:07 PM
flyinga flyinga is offline
What Dave said, pus if it isn't in the logbook it didn't happen. In future you might also want to know when it was that you last changed that tire, etc. Log it.
Jim Averett
RV-8
TS36 - Silver Wings
Fredericksburg, TX
Old 11-24-2014, 03:14 PM
Walt's Avatar
Walt Walt is online now
Dave
What does that mean exactly?
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 11-24-2014, 04:01 PM
You enter in the log book that the aircraft has been approved to fly again. If you have the repairmens certificate for your plane you do it. If you do not then I believe a IA must do it.
It is the same type of situation for the annual inspection. If you have the repairmen certificate then you approve the inspection and the return to service, if not then an IA must do the inspection and approve the return to service.
I believe I am correct. Almost positive.
Dave
Old 11-24-2014, 04:21 PM
scard's Avatar
scard scard is offline
Dave
Let me introduce you to Walt...
Walt, Go... :-)
Scott Card
CMW E-Lift
Old 11-24-2014, 04:48 PM
Before Walt.....
Anyone may work on an EAB airplane. No license needed.
The once a year condition inspection may be done by the holder of a repairman certificate for that airplane; or by an A&P (no IA needed).
Old 11-24-2014, 04:56 PM
Mel's Avatar
Mel Mel is offline
Dave
Repairman certificate is only required to perform the condition inspection on an EAB aircraft. Anyone can perform maintenance and/or modifications to EAB aircraft.
IA is not required for any sign-offs for EAB aircraft.
Annual condition inspection must be done by the certificated repairman for that aircraft or A&P mechanic.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 11-24-2014, 05:43 PM
Walt's Avatar
In addition to the above, an experimental aircraft only needs a "approved for service" type statement after a conditon inspection.
(a certified aircraft needs an approval for return to service after an annual inspection, major repair or major alteration).
Basically the aircraft was never "out of service" so it doesn't need to be "returned to service".
When accomplishing a repair or maintenance you only need to sign for the work you performed and that you performed a functional check of the sytem. Something like "repaired so and so, ops checked good", "changed oil and filter, leak checked good" etc. or a similarly worded statement is all that is required.
Old 11-24-2014, 05:57 PM
Bruce's Avatar
Bruce Bruce is offline
Thanks Walt
Bruce (BOOMER) Pauley
Kathy (KAT) Pauley
RV 7A--"MISS MARIE"--- N177WD (SOLD FLYING)72742
VAF #582-----------------EAA LIFETIME MEMBER
EX -KC-135A -------------BOOM OPERATOR #3633
VAN'S FLIGHT------------#6930
See you in OSHKOSH
http://www.mykitlog.com/users/index....ley&project=84
=VAF= 2006-2020 DUES PAID
