Old 11-22-2014, 01:55 PM
lr172 lr172 is offline
Default Baffle alignment Question
I am assembling the baffle kit on my O-320 (RV-6A build). I am working in the aft corner with the oil brace. The kit gives me a 1/16 spacer for the corner. However, without the spacer, I have a nice tight fit with the aft face of the #4 cylinder. The spacer would keep the aft baffle plate 1/16" off the cylinder. I assumed that I want this tight to force the air between the fins. Is that correct?
Thanks for your guidance.
Larry
