Old 11-22-2014, 10:15 AM
AX-O's Avatar
AX-O AX-O is offline
Default BNC connector question
I bough Princeton fuel senders. They came with a defferent connector than what i need. So i cut it off and was going to install a BNC connector. The connectors i have work on radio/xponder cable, so the collar is fairly big. The wire out of the princeton sender is like a 24 gauge wire. Do they make BNC connectors for wires that small? If so, where can i buy them. If not, what have others done? Thanks
Axel
RV-4 fastback thread and Pics
VAF 2020 paid VAF 704
Old 11-22-2014, 10:35 AM
wjb's Avatar
wjb wjb is online now
Check out the selection at L-Com ... they have every size of BNC connector, it seems
http://search.l-com.com/search/keywords-bnc_connecor
The Princeton units use a small diameter coax, like RG-174, and L-Com has connectors and cable assemblies for this. See if you can read the cable type from the jacket .. and match it up with the correct connector.
Bill Bencze
Old 11-22-2014, 11:22 AM
AX-O's Avatar
Thank you.
Axel
Old 11-22-2014, 11:38 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
Since it's not a RF signal it may not be a true co-ax cable, just a simple shielded single wire cable.
If this is the case, just pick the closest co-ax external diameter size and get the corresponding BNC connector.
http://en.wikipedia.org/wiki/Coaxial_cable
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
