Old 11-22-2014, 08:57 AM
Chris Engler Chris Engler is offline
Default Cranking Engine to Check Spinner Alignment
I'm in the process of adapting a Whirlwind 15 inch spinner to a Sensenich ground adjustable composite prop and would like to check spinner runout (I'm using the Showplanes cowl that requires a 15 inch spinner). Are there any issues with spinning the engine (Superior XP 400) using the starter without the prop blades attached? If this is feasible, should I remove one set of plugs from each cylinder to reduce compression and allow the engine to spin faster?
Chris Engler, Greene, NY
RV 8 Completed and Flying (N184CE), Showplanes Fastback and Cowl, Barrett IO-360; Dual GRT 10.4 HXr
Kitfox 7; Rotax 914, Built and Sold
VAF donation gladly paid through January 2021
Old 11-22-2014, 09:02 AM
JonJay's Avatar
JonJay JonJay is offline
Turn it by hand. It will be easier to see the runout anyway.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 11-22-2014, 09:11 AM
g zero g zero is offline
Default Spinner
By hand , easy to move before you drill . A cheap dial indicator is really handy for this .
Rv8
N 666 TA
First Flight 2-3-2015 🚀
2017 donation paid
Old 11-22-2014, 09:15 AM
rvbuilder2002's Avatar
+2 for by hand, but still remove one plug from each cyl to allow it to turn freely.
Scott McDaniels
Hubbard, Oregon
Old 11-22-2014, 09:19 AM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
No blades attached---------how U gonna turn by hand???
If the engine has been "pickled", you need to consider what spinning it will do to the long term preservative coating.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 11-22-2014, 09:47 AM
Easy!
If no prop is installed, then he must be using a spacer to simulate the prop hub
This can be risky BTW if you don't yet have the prop on the premises to confirm the dimension and you use the spacer while fitting the cowl).
What ever is used as a spacer can have holes in it for a piece of pipe to be used as a turning handle.
I agree with Mikes comment regarding the engine preservation though. Turning a pickled engine should be avoided as long as possible.
Scott McDaniels
Hubbard, Oregon
Old 11-22-2014, 10:06 AM
Thanks for the responses. I have the hub, prop blades, and spinner components....just thought it would be safer to rotate the engine without the blades if using the starter to spin. If turning by hand is the consensus, I can install the blades in the hub to rotate. Mainly looking to ensure the spinner rotates concentrically...sounds like using a dial indicator similar to the link below and rotating by had would be the best bet. The engine has been pickled but planning for a first start in the spring so thinking of adding the break in oil and rotating by hand won't be a problem at this point but let me know if this isn't correct.
http://www.harborfreight.com/clampin...tor-93051.html
Old 11-22-2014, 10:07 AM
Mike S's Avatar
Senior Curmudgeon
Eh, read the first post again.
Ground adjustable prop, no blades attached.
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 11-22-2014, 10:11 AM
Default Spinner
You can turn it by hand with the flywheel very easy ( no plugs of course )
Rv8
N 666 TA
2017 donation paid
Old 11-22-2014, 12:53 PM
pierre smith's Avatar
Default Don't need dial indicator.
We simply clamped a pencil to an A-frame ladder and moved it 'til the point of the pencil was extremely close to the spinner point and we could easily see which way we needed to bump the spinner.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
