Old 11-20-2014, 02:28 PM
jj_jetmech jj_jetmech is offline
Default Stall Warner access panel hole. Close it out forever? Good or bad idea?
I'm not installing the stall warner as I have a GAP 26 AOA probe... I think I'll rivet this access hole/panel VA 195 closed for good minus the screws and nut plates then fill the remaining edge gaps during paint.
Is there something I'm not considering that could cause a problem later? Can't think of a reason to ever need in there?
AP/IA/CFI/ATP/EAA TC
RV-7 Tip N77XA
Paid 11/15
Old 11-20-2014, 10:05 PM
xblueh2o xblueh2o is offline
It's for all the reasons I can't think of that I am going to leave mine removable but like you I can't think of a reason to go into that bay once the wing is complete.
Sam
RV-8 with the Showplanes Fastback conversion
Emp completed except for glass work
Wings completed except for bottom skin and glass work
Fuselage underway
N18451 reserved
Old 11-20-2014, 10:30 PM
N546RV's Avatar
N546RV N546RV is offline
I'm definitely on the fence about this one. I've been planning all along to just rivet the thing in place permanently, but now that I'm approaching the time when I'd actually do that, my reptilian brain is protesting on completely vague "what if" grounds, kind of like Sam mentions.
I'll probably still rivet it. I think.
Philip
-8 fuselage in progress (remember when I thought the wing kit had a lot of parts? HAHAHAHAHA)
http://rv.squawk1200.net
Old 11-20-2014, 10:50 PM
Jaypratt's Avatar
Jaypratt Jaypratt is offline
Default Extended range Gas
When you install the Hotel Wiskey extended range gas tanks in your RV! You will wish Vans made those inspection plates in Both! Wings.
Jay Pratt VAF #2
RV Central - Builder Assistance
Paul Revere, Borrowed Horse, & Shooter
Old 11-21-2014, 03:49 AM
cjhammes's Avatar
cjhammes cjhammes is offline
What is to be gained from removing access area and adding body filler on the underside of the wing?
Charlie Hammes
RV-8, N525RV Flying
RV-8, N208CH in process
Old 11-21-2014, 05:29 AM
Jesse's Avatar
Jesse Jesse is offline
I agree completely. There is no such thing as too many inspection panels.
Jesse Saint
Old 11-21-2014, 08:56 AM
RV7ator RV7ator is offline
I left the hole open. Also, I built and installed the sender and wiring, then removed the sender. The next owner can reinstall the sender if they desire.
I highly recommend tapping out the plate nuts, or turning down the leading threads of the screws. It' difficult reinstalling, or even aligning the hex key to loosen screws for repositioning of the sender, because of very limited volume and obstructions interfering with your ability to engage the screws - you can't see what you're doing.
John Siebold
Old 11-21-2014, 09:40 AM
Av8torTom's Avatar
Default Both
I installed a stall warner AND I'm planning an AOA instrument - why not???
N677AT reserved
Superior XP O-320, 160HP
Old 11-24-2014, 09:19 AM
It's not being removed it's just not be added. Original Vans parts not being used.
Plug patch, plate and doubler fabricated using no nut plates or screws.
Body filler not required but a very minimal amount could be used to hide the patch!
Why?
One less area beat up by dimples rivets and screws. Cleaner aerodynamic surface. No need to see inside that area anyway, If there was there would be an inspection plate on the other side.
RV-7 Tip N77XA
Paid 11/15
Old 11-24-2014, 09:23 AM
Ok maybe you should cut the same hole in the other wing so you can look in there and also see nothing, again... At least you'll have symmetry
RV-7 Tip N77XA
Paid 11/15
