Old 11-19-2014, 09:39 PM
cdeerinck's Avatar
cdeerinck cdeerinck is offline
Default Securing a servo connector
This is my roll auto pilot servo. Any ideas on how to best keep this DB-9 connector secured and out of the moving bits?
~Chuck
DG-800S Sailplane
QB RV-8 -- Working on final wiring and the engine
84CX Reserved
Old 11-19-2014, 10:00 PM
nilberg nilberg is offline
Why not drop the connector all togehter. Just connect the pins individually shrink tube each pin and then shrink tube all of them together. Steinair has a youtube video showing exactly that technique.
Then you can use an adel clamp secured to one of the nuts holding the tie-down bracket.
Old 11-20-2014, 07:21 AM
MarkW's Avatar
MarkW MarkW is offline
Chuck,
I partially agree with Nilberg. I don't care for the weight and clunk of the DB connectors. However I do like to be able to take them apart later when necessary. I would take the casings off and use small tiewraps to hold the two together. Then I would use the snake skin/chinesse finger trap sleeve material over the connectors to protect them. Then I would use tie wrap pads at both ends. I don't use the tape on pads but the ones without tape and then I use Proseal to hold them in place.
Mark
RV9 - N14MW - Flying
G3X - ECI Titan I0-320
Catto three blade prop
http://www.mykitlog.com/MarkW
Old 11-20-2014, 07:36 AM
cdeerinck's Avatar
Nilberg - I did just that for the tail trim, but was hoping to keep the plug here as Mark indicated.
Mark - your tip nailed it for me, not just here, but in other spots as well. The best part of what you suggested is using pro seal on the tie down plates. I hadn't thought of that. I just wish it didn't have such a short shelf life, and require mixing. Has anyone had success with a one part adhesive to do this? Even JB Weld is easier to deal with than Proseal.
~Chuck
DG-800S Sailplane
84CX Reserved
Old 11-20-2014, 07:45 AM
RV7AJeremy's Avatar
RV7AJeremy RV7AJeremy is offline
I reciently discovered this stuff thanks to someone here on the forums. It works great for this application.
http://www.amazon.com/Amazing-All-Pu.../dp/B0000A605I
Jeremy
ATP, CFI, CFII
RV-7 N424JD KCHD
EAA Tech Counselor
2017 Bronze Lindy
Old 11-20-2014, 08:44 AM
Ron RV8's Avatar
Ron RV8 Ron RV8 is offline
High strength self stick velcro holds these connectors in place quite nicely. One piece on each shell, a longer strip on the airframe... Mine haven't moved yet, only 85 hrs mind you... If the airframe you are attaching to is free standing you can safety with a couple of tie wraps...
Ron Townson
Okanagan Valley BC, Canada
RV-8 Completed Dec 2013
Membership renewed Sept 8, 2019
Old 11-20-2014, 08:52 AM
Here is the SteinAir video ...
click to watch video
For those who are planning to build their own panel, you will find the SteinAir videos a great asset. I wish I had discovered them sooner
Old 11-20-2014, 09:00 AM
Bavafa Bavafa is offline
what happens if you ever need to send the servo for repair, update or maintenance?
There are plenty of ways to keep the connector away and secure.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 11-20-2014, 09:16 AM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
Razor blade, slice off the heat shrink, pull the pins apart.
I have used this technique for a lot of places in my 10, here is the flap position sensor.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 11-20-2014, 10:31 AM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default "L" Bracket
Since you already have the connector installed, why not make and L bracket and rivet it in place. Mount the non servo side to the bracket and then use fasteners to attach the connectors as designed. You could have that done in 30 minutes. This will enable quick disconnect if needed.
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
