Old 11-18-2014, 09:34 AM
Kahuna's Avatar
Kahuna Kahuna is offline
Default Ceveland Brake parts wear
I have a sloppy brake caliper assembly. The anchor bolts #4 may be the worn part, or it may be the torque plate assembly item 17. $185
For those experienced brake folks, is it usually the anchor bolts (pins) or the plate receiver that wears?
Good answer would the the bolts at $25 each.
Parts breakdown here.
Kahuna
6A, S8 ,
Gold Hill, NC25
Old 11-18-2014, 09:38 AM
deek deek is offline
With 4,000+ hours on a set of 500x5 calipers I've replaced worn anchor pins twice; never the anchor plate.
'83 LongEZ - N888EZ 3,671 hours
'89 LimoEZ - N26EZ 686 hours (sold)
A couple of Glasairs and a Lancair 320...
Next: a RV14 need something to build
Old 11-18-2014, 04:07 PM
F1Boss's Avatar
F1Boss F1Boss is offline
Default Try Grove?
Eyeball engineering sez the Grove parts interchange. My bet is they are also cheaper, and of the same quality. Let me know if I can help.
Confirm: you're looking at #4 as it slides into #17? I have a spare of each if you want to try 'em.
Carry on!
Mark
