Old 11-18-2014, 05:26 AM
Dean Pichon Dean Pichon is offline
Default Drilling exhaust pipes for EGT probes
Next week, I will finally add 3 more EGT probes to my -4 as I install an engine monitor.
Is there any concern about getting chips inside the pipes? I assume they will get blown out immediately upon starting, but I thought I would double check...
Is there any advantage to plumbing a Shop Vac to the exhaust during drilling?
Old 11-18-2014, 06:50 AM
edsong's Avatar
edsong edsong is offline
Default Drill
Nope. Just drill
Edson Grindeland
Hatton, ND
RV-8 Flying
http://www.hattonflyingcircus.com
You do not need a parachute to skydive. You only need a parachute to skydive twice.
Old 11-18-2014, 07:04 AM
DanH's Avatar
DanH DanH is offline
If you're worried, put the cylinder on TDC with the valves closed, drill, then blow through your new hole with compressed air. The chips should come out the tailpipe.
FWIW, get them all the same distance from the flange, and oriented so the leads clear your spark plug socket.
Dan Horton
RV-8 SS
Barrett IO-390
