Old 11-17-2014, 05:06 PM
KJBSouth's Avatar
KJBSouth KJBSouth is offline
Talking Tip: 3 lb sledge
Were you ever so frustrated by a build problem that you wanted to use a three pound sledge hammer on aluminum?
Specifically when dimpling the most forward rivet hole in HS706 where the squeezer would not fit between the flanges? And, you didn't want to lay out the bucks for a thin die or grind down your C-frame?
Care not brother. Grab your 3/16" drill bit and two chunks of 1/8" steel plate. Let the chips fly.
When you're back in control, make a setup like this and call in your trusty sledge. Careful, don't hit that finger.
Ahh, the sweet sight of success. Enjoy.
The idea for this came with Vans airfoil practice kit. Thought you might enjoy the photos.
Karl Bambas
1954 1st solo
1964 Mooney Statesman, 1979 C-172, 1948 Globe Swift (all sold)
RV-7 "Dream Weaver" N50KB
Empennage arrived 10/14
QB Wings & Fuselage arrived 06/15
Finish & FF kits arrived 11/15
Dual screen Garmin G3X instruments and harness delivered by Stein 01/16
First flight June 13th 2018
2020 Dues Paid
Builders Log
Family Blog
Old 11-17-2014, 05:13 PM
wirejock's Avatar
wirejock wirejock is offline
Default Dimple plier
Been there.
Buy one of these. There are lots of places where they come in handy.
http://m.skygeek.com/aircraft-tool-s...iers-3-32.html
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 11-17-2014, 05:27 PM
bhester's Avatar
bhester bhester is offline
Thumbs up You'll want a set of these also
Or use these:
http://www.averytools.com/prodinfo.asp?number=1022
I used a no hole yoke a lot also.
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2019 VAF donator - alot better than any magazine subscription
Old 11-17-2014, 06:09 PM
N941WR's Avatar
N941WR N941WR is offline
Originally Posted by bhester View Post
Or use these:
Or one of these
http://www.averytools.com/prodinfo.asp?number=550
I did use a 3 lb sledgehammer but it was to set the front seal on my crank.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 11-17-2014, 09:09 PM
rzbill's Avatar
rzbill rzbill is offline
Or use these:
+1. The combo of no hole yoke and pop rivet dimple sets were my "Go to" tools for tight dimpling.
I always called that particular hammer a 'machinists hammer'. Anyone corroborate that name?
its the one to use for vice testing. If your vice can take a full swing, then its big enough.
Bill Pendergrass
ME/AE '82
Old 11-18-2014, 05:09 AM
catmandu's Avatar
catmandu catmandu is online now
The machinist I know always says "grab the BFH" when he wants that one.
Mike C.
Sierra Nevada
RV-6A bought flying
