10-21-2006, 03:20 PM
dimpling in narrow spots
I still haven't figured out how to dimple holes in tight spots between two flanges where the web gets very narrow (e.g. rudder ribs). When the web gets so narrow that the dimple die itself won't even fit between the flanges...
any suggestions?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
10-21-2006, 03:40 PM
The solution is pop-rivet dimple dies. You can get them from Cleaveland, Avery, and other tools shops. I purchased a set in both 3/32" and 1/8"; haven't used them much, but when I have nothing else would accomplish the task. I've ground them to fit in tight places as well; just have to make sure the face is polished to prevent scratches. It was perhaps the only time I've ever used a die grinder for it's intended purpose
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
10-21-2006, 03:45 PM
Pop Rivet Dimpler
The pop rivet dimplers usually work in this situation...
From Avery or Isham....
http://gallery.bcentral.com/Gallery/...=1&sortOrder=0
gil in Tucson
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
10-21-2006, 05:16 PM
I use a vice-grip dimpler from Avery Tools in this situation. It's hard to feed the mandrel for a pop-rivet dimple die through the hole in the trailing edge of control surface ribs.
Guy
10-21-2006, 05:51 PM
On some parts like the top rudder rib and the inboard elevator ribs, there is not even enough room to get the "pop rivet" dimpler in there. What I (and others) have done is to get a piece of steel angle and machine countersink the appropriate size "female" dimple into the angle. It helps to make it near the end and edge of the steel angle. Clamp the angle in the vice. Slide the rib over the hole and use the male dimple die and the ram from your c-frame dimpler to dimple the last hole or two on these ribs.
Aren't these RV-9(A) rudders fun?
10-21-2006, 05:59 PM
The only problem with that approach (which is quite clever) is that I don't have the c-frame dimpler... I have the DDRT-2 thing with the big handle. So I don't have anything to hold the male dimple die so that I can ram it down. I suppose I could drill a hole in a block of wood and put the die in that...
If i get a spot where the avery vice grip dimpler doesn't fit, I'll try that... for $35 I figured it was worth getting the vice grip tool.
Thanks!
Phil
RV9A (SB)
Ottawa, Canada
10-21-2006, 06:04 PM
You will use the vise-grip dimpler a lot! You may have to grind a little bit where the jaws are welded to the dimple dies in order to really get into tight places. Don't overdo it, though.
Ron Leach
RV-7 N713CM reserved VAF # 603
Cincinnati
__________________________________________
"Wish I didn't know now what I didn't know then".
.....Bob Seger
10-22-2006, 11:12 AM
I just realised I already have a pop-rivet dimple die. Looking at it, I don't understand when this tool would be useful. The female die is attached to a "nail" (I call it a nail because that's what it looks like) that goes up into the pop riveter. The male die slides down over the shank of the nail and the pop riveter squeezes the dies together by pulling up on the nail.
From what I can see, to dimple anything you have to have enough clearance on the opposite side to be able to poke that nail through the hole to be dimpled. This is quite impossible in a narrow flange. If I had enough clearance to get that nail in there, I would certainly have enough clearance to fit the yoke in there to use a squeezer for dimpling.
Also, there is an extra "nail" included with the dimple die, this one not attached to anything (no female die attached). What is this extra nail for?
Am I misunderstanding the functioning of this tool?
Phil
RV9A (SB)
Ottawa, Canada
10-22-2006, 11:46 AM
there are those who have and those who will...
The extra nail is there so when you pull too hard and break the first one, you have another. I think mine came with 6 or so extra nails -- already broke one. The local hardware store's aviation department carries more. -Jim
10-22-2006, 01:01 PM
The pop rivet dimple die is useful when you need to dimple a hole too far from an edge to use a squeezer, but there is some reason why you can't use the C-frame. I don't recall the details, but I know I ran into several places like that.
The nails get chewed up a bit by the jaws on the pop riveter, so you can only get a certain number of uses before you'll need to replace them with new ones.
There are some things you can do to help get the pop riveter in some places where it wouldn't normally fit. I don't think it will help you here, but it may be useful in other places - example
For the flanges near the ends of the ribs - I bent the flanges a bit to open them up and improve the clearance, did the dimpling with a Vise Grips dimpler (I think - that was a long time ago), then bent the flanges back to their original angle.
