Old 11-15-2014, 08:06 AM
dsmithlib's Avatar
dsmithlib dsmithlib is offline
Default DIY Jack Stands
Well, it was supposed to be so easy!
Jack Stand Photos.......
https://plus.google.com/photos/10345...38896336413537
After my last RV7 Condition Inspection I vowed to improve my jack-ability. I reviewed all the posts and then had a few requirements of my own.
build without machining
be able to take apart for storage
use the harbor freight ram
I was able to order all of the parts from Speedy Metals and had very few cuts. There was a fair amount of drilling, grinding and cleaning. Welding was done with TIG tacking and MIG welding - it could have all done with either.
One of the critical dimensions using the HF ram is height. So this was done with flat stock on the bottom. At the top, the receiver is merely a collar that goes about an 1" over the top of the ram to receive my carriage bolt in the tie location.
It was fun. However, the only way to claim that I saved any money would be if I valued my time @ 3 cents per hour. Pretty much like the entire airplane build.
DMS
Dave Smith,
RV 7 - tipup, O360
Completed- 1st flight April 2012
mail: dms789@yahoo.com
blog: http://rv7preflight.blogspot.com
Old 11-15-2014, 08:22 AM
DanH's Avatar
DanH DanH is offline
Dave, those are very nice.
It's such a pleasure to see a builder who does things just so.
Dan Horton
RV-8 SS
Barrett IO-390
Old 11-17-2014, 08:16 PM
MK77 MK77 is offline
Nice work Dave! Between the jack stands and the GSM hangar controller you've been busy!
Matt K.
RV-7 Tip-up - Flying!
XP Superior IO-360 w/cold air sump, Catto 3 blade prop
Garmin G3X
CFI, CFII, MEI
Old 11-17-2014, 09:16 PM
DaAV8R DaAV8R is offline
Default Jack
If anyone ever says you don't know jack, they will be very mistaken
Nicely done. What was your all in cost?
Robert Williams
Lee's Summit, MO
RV-8 - Empennage & Wings Done
Working on Fuse
O-360-A1A
1946 Cessna 120
Old 11-18-2014, 12:46 PM
johnso29 johnso29 is offline
Default Great Work! Could you possibly share the part numbers
Dave,
I've purchased the slave cylinders from Harbor Freight and am preparing to fabricate the mounting frame. I looked at the Speedy Metals website but don't know one piece from another. Could you possibly share the part numbers, sizes, etc. I'm sure many others would appreciate it also.
I have a friend with MIG welder who can weld it together.
Old 12-17-2014, 07:56 AM
dsmithlib's Avatar
Default BOM for Jack Stands
I posted my bill of materials as a jpeg in the photo library.
Plus the following.....
For the base material, let Speedy send you the correct sized pieces. Order 2x24 and 4x9.5
Add some angle tab material to hold the base in position. It is not in my BOM.
Dave
Dave Smith,
RV 7 - tipup, O360
Old 12-17-2014, 09:27 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Check your PM's Dave - nice job!
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 04-17-2018, 03:26 PM
Snowflake's Avatar
Dave, your Google photos link is broken... Any chance of an update to move the content to your Blog page instead?
Rob Prior
