11-14-2014, 09:02 PM
It feels smooth but I thought it would be a good idea to check it...
That's a common theme I hear when balancing props. Here's an example of what the owner thought was a smooth running machine. Vibration was approaching dangerously high levels.
The red circle represents the upper limit of 0.2 IPS, this one was at .758 IPS! (Finished at 0.040 IPS).
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
11-17-2014, 06:47 AM
Wow....there are many pilots that have never flown an aircraft that runs as smooth as it should and has a prop that is correctly balanced, so it may be hard to tell what is normal for some.
I like the data logging feature of that balancer, what is the make and model. I have an first generation DynaVibe. It is pretty crude, but does an OK job for low volume usage.
Mike Hammond
A&P IA PPL ASEL
RV-14A kit S/N 140170
11-17-2014, 09:00 AM
I have had the prop dynamically balanced on every airplane I've owned. I consider it a "must do" on every build. Although my RV-12 didn't require any weights, my Rocket was made significantly better after balancing.
Randy Pflanzer
Greenwood, IN
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
11-17-2014, 11:53 AM
So was the Hartzell on my -9A, NOTICALBE difference!
Long-EZ built 1985 -> Sold 2007
RV-9A; N539RV First Flight: 7/2010
RV-8A N468DL 40 hr Flight Test Program
Building Log: www.mykitlog.com/n539rv
APRS Tracking: aprs.fi/n539rv
2017 Paid
11-17-2014, 01:36 PM
I use the Dynamic Solution Systems MicroVib II, it's an excellent unit with lots of great features. The software package is an important feature (for me) as it allows you to capture, store and print records, log entries etc..
11-17-2014, 04:16 PM
Awesome
Way to go Walt.....that picture said more than an entire article could have! Thanks for posting this
Bob "Skyking" Corriveau
RV-8 QB Reserved N212KB
ATP
CFI/CFII/MEI
11-17-2014, 04:46 PM
I had the opposite experience.... It feels rough, so I thought it would be a good idea to check it...
The check showed it to be 0.06 IPS. I am considering having it done again to double check the first test....
11-17-2014, 05:11 PM
That is where the spectrum analysis can come in handy, our bodies are the most sensitive to the lower freq vibrations so looking at the 1/2 order vibs can reveal vibrations you may feel.
The 1/2 order and and 1.5 order vibs are indicative of cylinder gas pressures, so a cylinder that is not producing as much pressure as the others for whatever reason will show a high vibration in that area. Causes could be ignition, fuel, compression standard things..
11-17-2014, 08:45 PM
Walt, I wish I was just a little closer, I would ask that you do my prop. Anyone in the Atlanta area do this? What is the average cost?
Amir
RV-7
RV-10 - Sold
Supporting VAF since the first visit
11-18-2014, 07:08 AM
I had mine done at Palmetto Aviation Repair at St. Simons Island, GA (KSSI). It made a noticeable difference. IIRC it cost about $250.00 back in 2008 but I could be wrong.
