Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
Old 11-13-2014, 07:23 AM
DLussier DLussier is offline
Default Garmin 796 panel cutout
I would like to install my Garmin 796 in my panel without using the Airgizmo panel dock.
Anybody has a full size drawing of the cutout that they would like to share?:
Denis L.
RV6 C-GRIV
Lachute, Qu?bec
Old 11-13-2014, 07:47 AM
BCP Boys's Avatar
BCP Boys BCP Boys is offline
Instruction and spec sheets are on their website. All the measurements are there. http://www.airgizmos.com/795796-Panel-Dock_p_49.html
Amir
RV-7
RV-10 - Sold
Supporting VAF since the first visit
Old 11-13-2014, 07:51 AM
MS19087's Avatar
MS19087 MS19087 is online now
Default Stein will cut one for you
Did mine and it was perfect . . .
Mark
RV-9A; Sold
RV-14A; Building
2020 =VAF= donor
Old 11-13-2014, 08:32 AM
I am planning to modify the previous hole for a Lowrance Airmap 2000 in place without removing the panel.
Thanks Amir, I don't have the space to install an Airgizmo dock and their drawing is not to scale and not precise enough for me....I can always try to enlarge it...
Denis L.
RV6 C-GRIV
Lachute, Qu?bec
Old 11-13-2014, 11:24 AM
alpinelakespilot2000 alpinelakespilot2000 is offline
That's a coincidence, Denis. Just last month I replaced my Lowrance 2000c with the 696 since I could no longer get database updates. However, even without the airgizmo mount, I did not have enough vertical room to inset the 696. I envy you apparently having enough. I ended up just surface mounting it. It sticks out a bit more than I would have liked (about 1/2" more than the 2000c) but it's not too bad. I got used to it very quick and can wait until a major panel redo in order to inset it. I also did all the minor cut-outs and mounting with the panel in place. Pretty easy. Good luck with yours.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 11-13-2014, 02:43 PM
uk_figs's Avatar
uk_figs uk_figs is offline
Default Vertical or horizontal
Not sure how you plan to orient the 796 as it can be vertical or horizontal, in my case I mounted the unit horizontally below my D-100 and used the angled Gizmo 496 mount with a plate added that I bolted the 796 mount to, reduced the glare a bit and is easy to remove for updates etc
https://picasaweb.google.com/dbfiggi...81648394018914
Dave (Figs) (RV-7 N256F, Flying)
Dave's RV-7 Blog
Email me
Old 11-13-2014, 04:13 PM
Finley Atherton Finley Atherton is offline
I have completely replaced my panel but I had a 795 (same dimensions as the 796) installed in my old panel without the Airgizmo panel dock. At the time I installed it with the panel in place on the aircraft. Lots of trial, error and some filler however I got it pretty good in the end. It was recessed in the panel so only the black part of the side of the unit was visible. (none of the chrome part visible)
It was secured by the Garmin dock/clamp as shown in the photo with that structure attached to the top and bottom flanges of the instrument panel (tip up canopy).
I could easily use the cutout in the old panel to draw a template which I could email and if I add the exact horizontal and vertical dimensions you could adjust it to allow for size changes that might happen when sent as an email attachment. Let me know if I can help.
Anyone interested in a used 795 with an Australian data base which could presumably be changed to the USA??
Fin 9A
[IMG][/IMG]
[IMG][/IMG]
Old 11-13-2014, 07:54 PM
Thank you Fin, I would really appreciate it if you could do that.This is the way I was planning to install my 796 as I have seen other do. I will send you my personal email.
Denis L.
RV6 C-GRIV
Lachute, Qu?bec
