Keep VAF
Going
w/a Donation
VAF on Twitter:
@VansAirForceNet
11-13-2014, 05:42 AM
Garmin G3X RV-10 Autopilot Yaw Damper Option
Hello,
We are pleased to announce that we are now shipping the RV-10 yaw damper option for RV-10 aircraft equipped with either G3X or G3X Touch systems.
The RV-10 yaw damper is a ground up, new design created specifically for the RV-10. The yaw damper servo bracket ties in nicely to the aft end of the pitch servo bracket for an extremely rigid, yet relatively light weight installation.
The yaw damper installation kit (P/N 011-02952-16) includes the servo bracket and all the hardware needed for installation including the bridle cables and attachment blocks. You will also need a right angle connector kit (P/N 011-02950-01) to keep the servo wiring away from the elevator torque tube, and of course, another GSA 28 autopilot servo. Your existing G3X or G3X Touch software is already capable of supporting the yaw damper servo.
The Rev. P G3X Installation Manual that has been available for a few weeks already includes all the installation guidance including this image.
Before someone asks, the bow shown attached to the servo arm is there to make absolutely sure the rudder cables can never become entangled with the servo arm.
You will need either the GMC 305 autopilot control panel with the YD button, or a G3X Touch PFD which supports using the yaw damper with the touch screen autopilot control panel. The yaw damper servo can be engaged independently of the roll and pitch axis servos should you wish to hand fly the aircraft while letting the yaw damper servo handle the rudder. Many aircraft with a yaw damper engage the yaw damper shortly after takeoff and leave it engaged until just before landing.
Just a reminder that anyone can order the GMC 305 autopilot control panel with the yaw damper (YD) button, even if you don't presently have a yaw damper. This version of the panel costs no more than the version without a YD button, so if there is ever a possibility you will install a 3rd servo, make sure to order the GMC 305 with a YD button (P/N 010-01169-20).
The pitch, roll, and yaw damper axis all use identical GSA 28 servos. Just like the pitch and roll servos, the yaw damper servo supports auto-trim if you have electric trim installed for the rudder.
I was fortunate enough to get a ride to lunch at Stearman field in Wichita a few months back in an RV-10 equipped with a 3 axis G3X autopilot including this yaw damper option. This particular RV-10 has electric trim on all three axis. After we sat back and watched the autopilot fly the climb, cruise, and descent while auto-trimming all three axis and keeping the ball centered, the pilot builder/owner asked me if he still gets to log this time.
Let us know if you have questions.
Steve
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
Reason: Corrected part number
11-13-2014, 06:28 AM
Thanks guys!
My question is. We have kicked around the idea of putting the YAW damper in our "RV-8". Is this the same type of install we would see in that case? Thanks again, and good work guys. Yours as always. R.E.A. III #80888
11-13-2014, 07:20 AM
Yaw Damper in RV-8?
Hello Robert,
We haven't done the engineering analysis and 3D modeling to determine the hardware needed to install a GSA 28 servo as the yaw damper in any RV but the RV-10.
It is a pretty significant effort to design and test an installation like this, and even with all our tools, it took us a couple of iterations to get it right for the RV-10.
The RV-14 is so similar to the RV-10 that we hope this installation kit will also work there, but we haven't had a chance to verify this.
We will certainly consider adding yaw damper options for other aircraft based on the level of interest.
Another option is to create your own. Many builders have engineered their own yaw damper installation and connected it to the system.
Steve
Garmin G3X Support
g3xpert@garmin.com
11-13-2014, 09:09 AM
Trim Necessary?
Can you give the pros and cons of having trim with this system. Seems like the AP could fly without it, so it would only be a question of whether or not you're hand flying and wanted it, correct? I've heard some 10 builders say they didn't install any aileron trim or rudder trim, and just us the AP for this, but I'm not sure how well that works. Please tell me your thoughts, regarding the Garmin system..
11-13-2014, 09:25 AM
Just Incredible
I was in this same RV-10 while visiting my daughter a few weeks ago at KU. The owner had just installed the yaw damper. We went to lunch near Wichita and back. Wonderful and cool place to eat. What I found amazing is we flew the entire way back "hands-off" down to minimums in Lawrence KS. It was like the ball was stuck on dead center.
I totally get the owners comments about "can I still log the time".
PS: It was a gorgeous VFR day and the first time my wife had seen a finished RV-10. Up to that point she had just seen me in the garage with a bunch of metal (empennage).
Thanks again "Mr Owner"
Michael
Builders Blog http://elstien.us/wordpress/
RV-10 Builder
Tail Kit delivered 6-2013
Finished QB wings on September 2018
Moved to Port Orange Florida November 2018
Tailcone mounted to Fuselage on 3-1-2020
Finished Fuselage April / May 2020
Working working working on Doors
Engine Ordered (BPA/Fly-EFII 8/1/2020
Dues Paid through 2022
11-13-2014, 10:08 AM
Steve,
Is the right angle connector kit (P/N 011-02950-01) included in the top kit? For the price of the kit I hope it is included....
Gaylon Koenning
RV-10 #40468
N815DG, Flying
G3X, GTN750, GTS800
Barrett IO-540, 9:1, Cold Air,
Dual SDS Electronic Fuel/Ignition (EM5, V29.1)
Polly Ranch Airpark (7XS0)
Friendswood, TX
Dues Paid 2021
http://www.TexasRV10.com
11-13-2014, 03:55 PM
Yaw damper?
Is it really needed to have a yaw damper on a RV10? Please someone explain to me the purpose of a yaw damper.
11-13-2014, 04:11 PM
Not trying to be sarcastic but if your wife doesn't like the tail end wig wagging in turbulence constantly then yes having one is needed. The cirrus aircraft have them and sure make the aircraft much more stable for those folks who are uneasy in turbulence.
Gaylon Koenning
RV-10 #40468
N815DG, Flying
G3X, GTN750, GTS800
Friendswood, TX
Dues Paid 2021
11-13-2014, 04:21 PM
Good job, Garmin, for coming out with this. I'm impressed.
Dave
RV-3B under construction
11-13-2014, 07:28 PM
Hello Mike,
Good question.
The pilot and the autopilot servos have a lot in common. A pilot hand flying the plane doesn't like to continuously correct for an out of trim control axis and neither does the autopilot servo.
Can both the pilot and the servo expend more energy and still fly the plane even when out of trim? Yes, most of the time, but the pilot's leg can place more force through the rudder pedal than the servo can apply.
In an ideal installation with trim motors attached to the GSA 28 autopilot servos, the servos detect when they are working against an out-of-trim condition using built-in torque sensors and drive the trim motors as necessary to eliminate the out-of-trim condition and neutralize the forces on the servo. When this happens, the servos need only to apply relatively small forces to fly the plane just as the pilot would when flying a plane that is in trim.
The yaw damper dampens the yaw axis movements and makes the ride more comfortable, especially for those in the back seat in turbulent air, and also assists the yaw trim in keeping the ball centered.
You should not expect the yaw damper to also be the yaw trim. The yaw damper servo can assist in keeping the ball centered, but the manual or electric yaw trim should do the heavy lifting and we recommend installing the yaw damper servo in combination with yaw trim.
Steve
Garmin G3X Support
g3xpert@garmin.com
Reason: Clarified role of yaw damper and yaw trim.
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
