Old 11-12-2014, 07:06 AM
olyolson's Avatar
olyolson olyolson is offline
Default Magneto 500 hr inspection
I have Slick #4251 mags that will need the 500 hour inspection this winter. Having never checked a mag, I will have some adult supervision for the job. What are the most common parts I should have on hand for replacement while the mags are out?
Points? Condenser? Or???? I expect Acft Spruce will have these parts unless there is a better source.
Oly
RV-8, Flying
Previous airplanes: Corby Starlet, Citabria, Cessna 140, Vari-Viggen, RV-3, RV-4
RV grin every flight
"Sure is nice to have smart friends"
2018 dues paid
Old 11-12-2014, 08:07 AM
guccidude1 guccidude1 is online now
The 500 hr mag includes more that just replacing known wear items. Inspections of bearings, shaft play, case cracks, and testing the coils under load are normal SOP. I sent mine to a mag shop in the Seattle area and they came back looking new. Dan
Old 11-12-2014, 09:12 AM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
500 hr inspections are very reasonable price wise and do require more that changing parts. Send them in to a reputable shop and you have the inspection done correctly by the book.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 11-12-2014, 09:22 AM
olyolson's Avatar
Default Magneto 500hr Inspection
Thanks for the quick replies. I'm in the St. Louis area, anyone know of a shop nearby?
RV-8, Flying
2018 dues paid
Old 08-25-2015, 01:29 PM
Michael Burbidge Michael Burbidge is offline
Default Mag shop in Seattle area...
Where did you send your Mags in the Seattle area?
Michael-
Michael Burbidge
Sammamish, WA
RV-14A Empennage
RV-9A Flying?340 hours!
Last Donation: December 2019
Old 08-25-2015, 02:18 PM
akarmy's Avatar
akarmy akarmy is offline
I always used Aircraft Magneto Services, but they have moved to Montana now.
http://www.aircraftmagnetoservice.net
Andy Karmy
Covington WA
RV-8 - Flying!
RV-9A - sold
Dec 2019 Paid
Old 08-25-2015, 02:26 PM
Raymo's Avatar
Raymo Raymo is offline
Maxwell Magneto in FL is also recommended.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Old 08-25-2015, 06:58 PM
RickWoodall's Avatar
RickWoodall RickWoodall is offline
Default info
I just got mine back from aircraft magneto service. Great job, very compete and competent....and very good price.
JUST SHIP SLOW and have them SHIP BACK SLOW. $12 OR $14 each way is fine, but $100 for overnight air hurt a lot...just a miscommunication but was a bummer.
Rick Woodall C-GSTT "ghost"
9a -TMX io-320, catto three blade, dual dynon hdx with a/p. 900+ hrs in 8 yrs flying.
Flew to Osh 11,12,15,17,19. SNF 2013. West to Cali /Washington/Vancouver/crossed the Rockies north to Red Deer east to Moosonee and over to maritimes. South to Jekyll Isl, cedar key, and Key West etc. 6 trips and 17 islands of the Bahamas. Flown turtles and dogs for Pilots n Paws too. Love our Rv's
Old 08-26-2015, 08:57 AM
rph142's Avatar
rph142 rph142 is offline
How much does a 500 hour inspection cost for bendix mags? Mine will be due for inspection later this year and I'm on the fence about upgrading to P-mags.
Rob Holmes
www.myrv3.com
N59LG
The minimum number of planes one should own is one. The correct number is n+1, where n is the number of planes currently owned. This equation may also be re-written as s-1, where s is the number of planes owned that would result in separation from your partner.
- Veluminati
Old 08-26-2015, 09:36 AM
SMRacer SMRacer is online now
Default 500 hours
Are inspections of this nature usually based on tach time? Thus since we generally use Hobbs meters and they accrue time faster than the tach, can we legitimately delay the 500 hour inspection to some greater number on the Hobbs.
What is the generally accepted percentage relationship between tach time and Hobbs time?
Jim
N444JT
