11-11-2014, 11:10 PM
What would you do with this?
My throttle produces severely offset CHTs and EGTs at about a 75% position. If I dump in full throttle or pull back to 65% or less all the numbers even out nicely though. I've verified I can get a good EGT rise at altitude by leaning. But this spot around 75% has some wicked offsets. Aerosprort was of little help.
Derek Hoeschen
EAA Tech Counselor
RV-9A #92103 - N803DK
G3X, Superior XO-320, Dual Pmags, Catto 3B
www.mykitlog.com/dbro172/
1974 Bellanca Super Viking - N16AW - Flying
RV-8 #83565 - N184DK - building
1968 Mooney M20C - N6801N - Sold
1956 C-182 - N744W - Sold
11-12-2014, 12:21 AM
I'd lean the engine out. 11.7 GPH on an O320 is a ton of fuel at 72% power on an O320. It's enough to support almost 170 HP, and you're producing about 115.
Does it clean up when you drop to 10-ish GPH, which is much more in line with a ROP mixture at that power?
What do your fuel flows look like at WOT and 65% power?
--Ian
Dynon Avionics
11-12-2014, 12:39 AM
I will have to lean it out and check to respond to your question but I think it has more to do with the butterfly valve setting. I can check fuel flow at wot and 65% power but that will pry mean climbing to 12500 da or so?
I think I'm realizing some significant ram air horsepower or some significant horsepower increase from the ASA vacuum valve because whereas I only get 2150 rpm static at 1500 msl, I can still wind it up to 2750 at 10,000 DA.
Derek Hoeschen
EAA Tech Counselor
11-12-2014, 05:04 AM
sump riser insert
do you have a sump riser insert? lycoming SB-258.
Steve Melton
Cincinnati, OH
www.rvplasticparts.com
11-12-2014, 07:05 AM
Extremely old SB and it looks like he has a Superior 320. Lean for the altitude and report back, that's a lot of fuel burn.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
11-12-2014, 07:28 AM
Agree with the leaning recommendation
I have likely the same engine in a 9A - Superior IO-320 - furnished by Aerosport Power. At that altitude and at 72% power I'd be leaned w-a-y back and burning 6.5gph or less. Even at <4000 ft running 75% and 100 ROP my fuel burn is ~ 9 to 9.3gph. That 11.7 - as others have observed - is WAY high.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
11-12-2014, 09:21 AM
RPM 2690
I take it that you have a fixed pitch propeller. A sweet spot at nearly 2700 RPM?
If you had a constant speed prop, you could set around 23/23, lean to around 6-7 GPH and watch things quiet down and cool off.
Danny King
Beautiful Doll 80434 TT 1675 hours
I0360 A1B6 200 HP
Christen Inverted Oil
First Flight 12 July 2000
VAF Dues current for 2020
11-12-2014, 09:24 AM
Here is a photo and my sump riser (spacer) that was asked about previously. Perhaps it should be above the throttle bracket?
Derek Hoeschen
EAA Tech Counselor
11-12-2014, 09:37 AM
Yes... and mounted inside the bottom of the sump. You have a Superior Engine, not going to be your issue.
Reiley
VAF# 671
Friend of the RV-1
11-12-2014, 09:53 AM
Reiley - can you clarify your response? are you saying the brown spacer should be above the white throttle bracket?
Derek Hoeschen
EAA Tech Counselor
