Originally Posted by bsvantho
I am also reconsidering the use of the double sided tape mounting bases. I will probably use #6 screws with adel clamps or a tie wrap base with a center hole.
I used a couple of the square nylon ty-wrap bases, but drilled a #30 hole and used a pulled rivet to make sure they stay where I put 'em. Cheaper and lighter than an adel, screw and nut.
Edit: Actually, I just thought about it... I didn't even drill the hole where I did this, there was a convenient unused #30 rivet or tooling hole that just happened to be in the spot where I needed it.
