Old 11-10-2014, 09:52 AM
woxofswa woxofswa is offline
Default Kitplanes photo oddity
I recently glanced at the latest issue and something jumped out at me from a pix on the cover.
Am I nuts or does the picture on the cover of Rob Hickman's exceptional RV-10 show his nose wheel and fairing cocked slightly out of pointing directly into the airstream?
IT could just be an optical illusion or a photo/print anomaly, but it got me wondering if there was a possibility that for whatever reason the nose gear could sometimes slew itself to the side in flight.
Myron Nelson
Mesa, AZ
RV-10 N24EV
KITPLANES Contributing Editor
Old 11-10-2014, 09:56 AM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
This has been discussed in the past, as I recall folks were attributing it to the spiraling prop wash.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 11-10-2014, 12:16 PM
Ironflight's Avatar
VAF Moderator / Line Boy
All I can tell you is that we didn't manipulate the picture in any way (at Kitplanes), so what you see is what was there. Perhaps it was reacting to the prop slipstream as Mike says, and there were rapid power changes in involved to stay in formation.
That is a stock photo from our archives BTW - not something recently taken.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 11-10-2014, 12:21 PM
Interesting. For grins I searched the interwebs for every photo of a flying RV10 I could find and I found 8 that appeared dead straight and one that looked just like the cover shot.
My guess so far is that it is temporary phenomena that happens in certain situations and that shot just happened to catch it.
Myron Nelson
Mesa, AZ
RV-10 N24EV
Old 11-10-2014, 12:31 PM
Low Pass's Avatar
Low Pass Low Pass is offline
Or maybe the plane is cross-controlled for a nice camera angle?
Old 11-10-2014, 01:13 PM
Mike S's Avatar
Senior Curmudgeon
http://www.vansairforce.com/communit...d.php?t=104661
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 11-10-2014, 04:12 PM
vic syracuse vic syracuse is offline
Super Moderator
Default Yes, they do that
I remember being in my RV-10 with Van himself doing the flying, and we were in formation with the factory RV-10 and Van mentioned that the nosewheels sometimes **** off to a side.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
Old 11-10-2014, 07:19 PM
rwtalbot rwtalbot is offline
I have experienced this in my 7A in heavy crosswinds. You can feel the nose gear "snap" back to centre as it touches the runway.
There is a lot of keel surface on the back and it is free to caster, so not really surprising. It will follow the relative airflow.
Richard Talbot
RV-7A
Sydney, Australia
Old 11-10-2014, 11:51 PM
PCHunt PCHunt is online now
I'm thinkin' that unless you put in a crosswind correction, i.e. a "Slip", a crosswind would make no difference.
Once you are airborne, and the ball is in the middle, the aircraft doesn't "feel" a crosswind.
However, and intentional cross-control for a photo sounds more like it.
Pete Hunt, [San Diego] VAF #1069
RV-6, RV-6A, T-6G
ATP, CFII, A&P
2020 Donation+, Gladly Sent
Old 11-11-2014, 05:40 AM
Weasel's Avatar
Weasel Weasel is offline
So is the relative flow at that location flowing from left to right? think about the prop direction of rotation.
BTW it does the same on all of the -10 airplanes that I have flown if the caster nut is loose.
Weasel
RV-4 715hr Sold
RV-10 "School Bus" - +1600hr counting
Fisher Classic Cassler Power VW sold
RV-10 N7631T 820hr Sold
RV-8 700+hrs
Carbon Cub 200 hr Sold
One-Off Super Cub 100 hr
SERFI AWARDS
http://weaselrv10.blogspot.com/
