Old 11-09-2014, 11:59 AM
Toobuilder's Avatar
Question ACS Flap Control Board
I have an Advanced Control Systems PN 70025 Flap Control Board in my Rocket and I'm trying to figure out what it does. The flaps run up and down with the switch just fine, but is that all it is - a relay panel?
I can't seem to find a website or any real info about this thing.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 11-10-2014, 03:48 AM
chris mitchell chris mitchell is offline
Unless it lets you select an intermediate position, I can't see that it's anything more than a relay board?? Probably an expensive way to reproduce something that could be done with a quick trip to RadioShack and an hour with a soldering iron. Perhaps I'm just being cynical!
Chris
Chris Mitchell
Repeat offender;
RV-8, QB, built, flown 150 hours, sold;
RV-4 - attempted repair, rebuild and remediation - abandoned and junked ;
RV-4 fuselage and wing kits - both at QB stage;
2015-2018 dues paid!
Old 11-11-2014, 08:04 AM
Mich48041 Mich48041 is offline
Some controllers send a Pulse Width Modulated (PWM) current to the motor. The PWM current can vary the speed of the motor while still providing full torque.
Joe Gores
RV-12 Flying
Old 11-11-2014, 10:17 AM
Walt's Avatar
Walt Walt is offline
Relays basically switch higher currents using small control currents, they are usually installed in RV's when a low current rated stick grip switch is used to control the higher flap motor current.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
