I've been chasing an issue where air was getting into my fuel line causing cold start issues where a cylinder will drop off due to getting a slug of air. Weeks of changing lines etc and I finally decided to cap the Andair tank selector lines and pressurize the airframe side from the firewall with 10psi. Squirted some soapy water and found this:
Has anyone else had one of these pumps leak? It is leaking from a joint on the body where the bubbles can be seen. Been in service 7 months.
