Old 11-06-2014, 04:45 PM
mill2978's Avatar
mill2978 mill2978 is offline
Unhappy Rivet factory head failure - can anyone tell me how this happens?
While I was riveting ribs to rear spar on my RV8 wings and 5 AN470AD4-8 factory heads failed in the same way.
I was hand bucking these with a double offset cup and a tungsten bucking bar. I was using ~45PSI and the shop head was well formed. I had an assistant who was holding the rivet gun perpendicular to the work so I could focus on squeezing the trigger and forming the shop head. When we lifted the rivet gun the factory head just fell out of the cup. leaving the rest of the rivet in place.
Any ideas how this happens? Was this technique or could I have other rivets that are ready to fail in a similar way? I inspected(including some light prying on the rest with no failures) and don't see any indication of problems.
Aaron Miller
RV8 N127KT - First Flight October 16, 2018
http://www.mykitlog.com/AaronMiller/
Old 11-06-2014, 04:50 PM
Steve Melton's Avatar
Steve Melton Steve Melton is online now
Default defective rivet?
I don't know much about rivets but could it be a defect in the rivet itself?
Steve Melton
Cincinnati, OH
www.rvplasticparts.com
Old 11-06-2014, 05:44 PM
Charles in SC Charles in SC is offline
I would say bad rivets, I would probably drill out some or all of them and see what they look like. I am sure someone else will chime in on this but if you do not get to the bottom of it you will always wonder. The only time I have seen rivet heads come off like that it was due to salt water corrosion on some old over seas containers.
RV 7
Old 11-06-2014, 06:02 PM
mill2978's Avatar
Default Close ups of 3 heads
When I was cleaning up I mistakenly dumped the heads in the trash, i dug through it and found 3 of the 5, here they are in close up.
Top of factory head pre clean:
Bottom of factory head pre clean:
Top after rinse in MEK:
Bottom after rinse in MEK:
Aaron Miller
Old 11-06-2014, 06:14 PM
aerhed aerhed is offline
Your offset set is clearly sideloading the mfg head. You can see where they sheared in the upside down shot. Also looks like the cup is slightly undersize leaving an extruded rim around the head. Drill em all out and try another setup.
Actual repeat offender.
Old 11-06-2014, 06:20 PM
aeroaddict's Avatar
aeroaddict aeroaddict is offline
Yup, exactly what Arehed said. Even though the factory head appears ok (sans the ring) the bottom of the head show signs of shear; the area that has uniform parallel lines. The other part of the fracture area is the ductile failure after enough of the cross sectional area was reduced by the shearing action.
Corrective action; ensure the set is perpendicular (or in axial alignment with the rivet) to the piece being riveted.
Dan
RV-7 Slow Build - Sold
KEUL
Old 11-06-2014, 06:38 PM
mill2978's Avatar
Aerhed and Dan thanks for the help. I would much rather this be an issue of technique than of defective rivets.
Aaron Miller
Old 11-06-2014, 07:12 PM
airguy's Avatar
airguy airguy is offline
Yup, this is technique - the force was not perpendicular to the rivet head, there is some side load there that is shearing the rivet.
Old 11-06-2014, 08:59 PM
PCHunt PCHunt is offline
Can you squeeze these rivets instead of driving them? Much less likely to shear the heads, IMHO.
I personally prefer to squeeze a rivet than buck it, if I can.
As always: YMMV!
BTW: Very sharp eyes, AERHED!! Well done.
Pete Hunt, [San Diego] VAF #1069
RV-6, RV-6A, T-6G
ATP, CFII, A&P
2020 Donation+, Gladly Sent
Old 11-06-2014, 11:09 PM
ijustwannafly's Avatar
ijustwannafly ijustwannafly is offline
This is a good read for a newbie like me.
Sorry you are having some difficulty with that set but thanks for posting it up for new guys like me to read and learn about.
