Originally Posted by JohnInReno
I take this to mean that it is ok to use the existing p-lead in an upgrade, but make sure it is not inadvertently grounded.
Correct.
The way the standard P-mag wiring works is to power the P-mags up when the Master is turned on. Then the ignition switch grounds them, just like a standard mag. Grounded, no spark, ungrounded, spark.
The difference with the P-mag is that when the P-mags are powered up and grounded, they are in "setup mode". Meaning that you can blow in the tube and set top dead center when they are powered up and grounded.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
