Old 11-05-2014, 02:55 PM
thad14433 thad14433 is offline
Default "Quickly remove protective film." from aluminum
Unable to open post with this info. Help Please! Have some 10 years old parts.
Old 11-05-2014, 03:14 PM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
Default Welcome to VAF!
Thad, welcome to VAF
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 11-05-2014, 03:18 PM
xavierm xavierm is offline
Default Page is gone
Here's what's on the Way Back Machine (internet archive)
https://web.archive.org/web/20110323...ilder_tips.htm
No pics, but the description is there.
_____________
Xavier
RV-7 build in progress
www.theaviatorx.com
"Genius is persistence in disguise"
Old 11-05-2014, 03:40 PM
wirejock's Avatar
wirejock wirejock is offline
Default Blue vinyl
Heat helps too. Use a hair dryer.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 11-05-2014, 03:51 PM
Thanks, my film maybe too dry and brittle for this method, but I'll sure give it a try. At this point the only thing that works at all is the fingernail scratch method. It may take paint remover.
Old 11-05-2014, 04:02 PM
wirejock's Avatar
Default Chemicals
Don't put paint remover on aluminum. Some products have chemicals that could damage the aluminum. Laquer thinner maybe.
Larry Larson
Estes Park, CO
Disclaimer
Old 11-05-2014, 04:38 PM
grubbat's Avatar
grubbat grubbat is offline
Default Steam
I couldn't get the blue film off several panels that were sun dried for several years. I tried alcohol, thinner, mek, glue remover, stripper, sun,hair dryer, iron, heat lamp, you name it.
This morning I finally was able to get it off with a commercial jiffy steamer that I borrowed from momma. It took about 4 hours to do two bottom wing panels. The steam loosened the plastic and off it came with persuasion from a plastic scrapper.
Next time, I'll just reorder the panels from Vans.
Craig
RV-3 Sold
RV-4 Sold
RV-6a Sold
RV-9 IO-360 CS, Built and Flying
Aerostar 600A, Family Hotrod
Old 11-06-2014, 02:13 AM
Before seeing the caution against paint stripper. I applied a product called Klean Strip, KS-3 that claims to be safe on aluminum. In 10 minutes the coating bubbled up as paint would and easily scraped off with wood block and then washed with mineral spirits, per instructions. No visible damage or change in appearance of the aluminum. This coating had a black base coat and white outer coat. I think I'll watch it for a few days for changes before using on non-critical, non-structural part. Thanks again for everyone's helpful comments!
