My $.02 - I'd suggest very minimal engine runs - certainly no "taxi testing" (as tempting as it may be). I'd suggest only two; each limited to 2 minutes or 300 CHT whichever comes first. The first run to 2000 RPM - insure it runs, indications are normal and no leaks. Let it completely cool down. The second run, to determine static RPM / insure that you have takeoff power.
I recommend you tow the airplane to the runway (you probably won't be able to meet the 2 minute / 300 CHT limit if you taxi). Full power for takeoff, and when at a safe altitude, very shallow climb rate and throttle back - goal to keep at least 75% power while keeping temps as low as possible. You should see the initial ring seating in about 20 minutes - temps (CHT & EGT) will drop noticeably and somewhere around 30 - 40 minutes I'd conclude the flight to look for any leaks or anything that got loose, etc.
I've done this a few times, and the engines have done very well.
Dan
RV7A (N7101) - Flying 10/2008
CFI- SE/ME/Inst
A&P
KC2ZEL
