Old 11-05-2014, 10:48 AM
ALMARTON ALMARTON is offline
Exclamation WX-500 stormscope compatible displays or interfaces ?
I would like again to take advantage of the vast knowledge here on VAF:
I'm building a RV7A with a G3X GDU 460 touch.
I plan to install also a WX-500 Stormscope.
I believe there isn't yet support to integrate WX-500 with the G3X touch.
I think GTN 750 / 650 are both too much expensive to be mostly used as interface for the stormscope.
So I am looking for alternative solutions and suggestions.
Is there any cost effective solution from Garmin or other for interfacing with WX500 ?
Either that or a nice slave display especification to suggest?
If so please provide links for princing info...
Many thanks in advance.
Alexandre "neck" Marton
Brazil
RV7A (8/2015 built by FLYER)
Lycoming 180 HP - YIO-360-M1B, Hartzell C2YR-1BFP/F7497? 72??, Garmin panel - G3X Touch, GTN650, GTS800, WX-500, BATT CONCORDE RG-25XC AEROBATIC SEALED.
Others: RV9A
Lycoming XIO320-D1A, Hartzell HC-C2YL-1BF/F7663-4 , CS GOVERNOR MTV-12-B, DYNON D180
AND GARMIN AVIONICS
(Sold with aprox 300hrs flown from Dec/2010 -- JUN/2014)
Old 11-05-2014, 11:26 AM
g3xpert's Avatar
g3xpert g3xpert is offline
Post
Hello,
Please see this response to your question in another thread.
Steve
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
