11-03-2014, 10:32 AM
Dynon heated pitot controller
I am installing my Dynon heated pitot controller. It sure would make my life much easier if I could ground this thing locally to the airframe. The instructions advise to take the ground to the source. Anybody ground locally? Have any problems doing so? Thanks
RV-3 Rebuilding
RV-9 Flying and having fun, experimenting and having fun, did I mention flying and having fun?
RV-6A SOLD
Maule M5-235C SOLD
C-172G SOLD
Stinson L5 SOLD
Grumman AA1A SOLD
11-03-2014, 11:13 AM
Go for it.
I have it grounded locally. No problems with over 1800 hours of use.
Ron Schreck
IAC National Judge
RV-8, "Miss Izzy", 2250 Hours - Sold
VAF 2021 Donor
11-03-2014, 04:14 PM
You may not suffer any problems, but running one wire or two at the same time is not any extra work.
The controller takes several amps, into double digits and when you get weird radio noise problems from strobes and pitot heat controllers and other devices you start wishing that the shortcuts were not taken.
Its one wire or two wires?..not much harder, and less risk.
______________________________
David Brown
DYNON Authorised Dealer and Installer
The two best investments you can make, by any financial test, an EMS and APS!
11-03-2014, 04:32 PM
Its one wire or two wires…..not much harder, and less risk.
But qualifying that risk is what an engineer would do. In this case, the risk is small since the device is well-shielded/grounded - it's enclosed in an aluminum box that is bolted to and therefore at ground potential. Additionally, the device *may* be passive i.e. not contain any switching circuitry and therefore not have an RF emission potential.
I've had mine grounded locally with no RF of any kind, and in looking at installation manual for my Dynon, I can't find where it suggests grounding it to a common source other than the aircraft itself which implies local grounding is sufficient. If a separate ground run is used, be sure to re-check wire sizes accordingly to account for the added voltage drop the additional run length will introduce. This probably means going from a 16 gauge wire to a 14 gauge wire, but check the Dynon install manual (or AC43.13B) to be sure.
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
11-03-2014, 05:34 PM
I ground it locally in the wing with no issues after 2 years and 340 hours
Bill Peyton
RV-10 - 1125 hrs
N37CP
First Flight Oct 2012
Aviation Partners, LLC
11-03-2014, 09:52 PM
Jrsky god Dynon heated pitot
Say did get the new dynon pitot tube that was just released. There was a service e bulletin on the tube and not the controller. Just a note.
Ron in Oregon
11-04-2014, 07:55 AM
Running another wire will mean installing larger bushings in the rib holes so I'm gonna try the local ground first. I did get the new probe, Ser. No. 6100
RV-3 Rebuilding
RV-6A SOLD
Maule M5-235C SOLD
C-172G SOLD
Stinson L5 SOLD
Grumman AA1A SOLD
