Old 10-29-2014, 03:11 PM
s10sakota's Avatar
s10sakota s10sakota is offline
Default Rivets are deforming bulkheads!
Anybody know why this is happening? When I squeeze the rivets on the fuselage bulkheads, it's deforming the bulkheads. In fact, it was so bad on the F-705 bulkhead that I've scrapped all three lower pieces and re-ordered new ones.
Now as I'm riveting the second bulkhead, I squeezed two rivets and then noticed it's doing it again.
I'm clearly not over-squeezing them, but I'm not sure how to keep the bulkheads from deforming when I rivet them.
Here's two of the two rivets I just tried installing pics...
Do you see how when I squeeze the rivet it's pulling the bulkheads apart? I will drill these two out and straighten the bulkheads, but I don't know what to do differently with the new rivets!
Help!!
Mark Pensenstadler
1962 Piper Cherokee 160
2003 RANS S-10
2011 RANS S-6S
2011 Vans RV-7
2015 Zenith Cruzer
1962 Mooney M20C
2019 KITFOX Super Sport
Old 10-29-2014, 03:23 PM
JonJay's Avatar
JonJay JonJay is offline
The rivets are swelling between skins. Clamp the flange as close to the rivet as you can before you squeeze. This should keep this from happening.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 10-29-2014, 03:48 PM
David Paule David Paule is online now
I've used short lengths of back fuel line, about the length of the exposed rivet tang, to press the flange down while riveting. Works very well.
Dave
Old 10-29-2014, 03:52 PM
airguy's Avatar
airguy airguy is offline
Yep, keep your parts clamped firmly together during riveting and this won't be a problem.
Garden City, TX VAF 2021 dues paid
N16GN flying 900 hrs and counting; IO360, SDS, WWRV200, Dynon HDX, IFD440, G5
Old 10-29-2014, 04:11 PM
s10sakota's Avatar
Okay thanks for the replies. I like the idea of the black fuel line!
Mark Pensenstadler
2003 RANS S-10
2011 RANS S-6S
2011 Vans RV-7
2015 Zenith Cruzer
1962 Mooney M20C
Old 10-29-2014, 05:09 PM
Echo Tango Echo Tango is offline
i have o-rings i put around my bucking bar
works great
Old 10-29-2014, 05:54 PM
AAflyer's Avatar
AAflyer AAflyer is offline
Default Backset
Wouldn't a backset do the same thing? You'll probably need a rivet backset for other parts of your build, and this might be the place to start. A backset has a collar that is spring loaded, so it will put good pressure on the parts, to close that gap. There might be a video in Hints for Homebuilders on the EAA site that will show you what I can't easily describe.
Of course this may not be appropriate for a round head rivet.
Bruce Windom
QB RV-8 N148BW
First Flight: Oct '16
AeroSport Power IO-360 180hp w/dual P-Mags
Catto 3-blade, with black carbon spinner.
10" Dynon SkyviewTouch. That's ALL.
Old 10-29-2014, 06:16 PM
flion's Avatar
flion flion is offline
Yes, a back riveting set does the same kind of thing but I don't think I've seen one that would fit in a squeezer. I've generally found this to happen when the squeezer puts a side-load on the rivet and/or work. For example, if I'm trying to hold the work in one hand and operate the squeezer with the other hand, it is almost impossible to keep everything aligned. I get good results with a second pair of hands or putting the work in a vice so I can use both hands with the squeezer. If it feels like you need three hands, you probably do. The alternative is the rigidly mounted squeezer that you can use two hands to feed the work into. In either case, both the work and the tool need to be stable and aligned properly with each other.
EAA Technical Counselor #5357
Old 10-29-2014, 06:53 PM
BillL BillL is offline
works great
Good idea, consistent thickness and get an assortment at the hardware store.
Bill
RV-7
Old 10-29-2014, 07:33 PM
Norman CYYJ Norman CYYJ is offline
You can draw the rivet, squeeze the parts together then set the rivet.
