Go Back   VAF Forums > Model Specific > RV-4
  #11
Old 10-29-2014, 11:56 PM
Doug's Avatar
Doug Doug is offline
Probably not an RV-4.
Doug Gray
RV-6 completed, flying since July 2010
Old 10-30-2014, 07:34 AM
Snowflake's Avatar
Originally Posted by southtarnation View Post
If someone (a laymen) looked at it from the top where it meets (or would meet) in the cabin it might look like wood due to it looking similar to several thin(er) pieces of wood that have been laminated into a single "spar".
Best explanation yet. Maybe the current owner bought it used and doesn't really know how it was built. All those laminations coming together in the middle could be mistaken for wood grain, I guess. Especially if it was painted brown...
Rob Prior
Old 10-30-2014, 08:04 AM
rbibb's Avatar
rbibb rbibb is offline
The RV-4 has had only one spar design for its entire life as far as I know. The only "options" where whether one tapered the laminated stiffeners in length.
The spar (similar to all RVs) has a large U Shaped channel (web) that is formed from bent aluminum. To both the front and aft sides of this piece 1/8" thick (going from memory here) stiffeners are riveted to the spar web using 3/16" rivets. The stiffeners strips are about 1 - 1.5" wide and are stacked on top of one another to make the complete thickness of the spar.
Since loads lessen the farther toward the wingtip you go the need for stiffeners to meet the designed load carrying ability decreases, hence the number of stiffeners decreases. Indeed for the last foot or two only one stiffener thickness (forward side) is needed.
Also, the stiffeners were made from 1/8" x 1.5" (I think) bar stock (a standard size. In order to save weight the builder could optionally taper the spar strips in width per the plans. Builders of later model RVs will see the same design feature in the machined dimensions of the one piece stiffener used in later models. Access to a CNC machine makes fabrication simpler than when you are doing things with a hacksaw.
Back in the day there used to be discussions and such in the early editions of the RVator as to techniques the builder without access to a machine shop could use to cut such tapers. The best answers usually involved a bandsaw but using a hollow-ground planer blade on a table saw produced the nicest finish IIRC.
All eventually came to naught as the availability of pre-made spars with machined cut tapers, anodized finished parts, and precise set rivets (in a brake press probably) made user fabricated spars as rare as humble tail-dragger pilots.
So, if that plane is an RV-4 it has a metal spar. Only question is was it pre-made by Phlogiston (a good thing) or made by the builder (something that just needs a bit more inspection but, in itself, no reason to run for the hills).
If, upon inspection you see anything that looks like wood, congratulate yourself on finding a rare, probably one-of-a-kind example of the homebuilt aircraft world. But just know that it ain't an RV-4 even if you can understand why someone might want to claim to be one of the best flying airplanes ever designed.
Richard Bibb
RV-4 N144KT
Fredericksburg, VA
KEZF
Old 10-30-2014, 08:22 AM
eisnerrv4 eisnerrv4 is offline
Thumbs up RV-4 Spar
No sense adding my two cents worth. It's all been covered.
Good luck in purchasing one. Fabulous aircraft.
Brian Eisner
RV-4 C-GRJT
Bedford Nova Scotia
Canada
Dues paid for 2019
Old 10-30-2014, 08:39 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Gotta remember that one
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 10-31-2014, 12:46 PM
Larryskydives Larryskydives is offline
Thanks for all of the info. Knowledge is power. Talked with the owner again and asked if he was sure it was wood. Said it was, after I told him what I had found out, he said maybe it wasn't wood. I tend to think that the laminated look at a distance looked like a wood grain. But all for naught, I think he has sold it today.
On another note, I just can't understand a person buying an airplane. experimental or certified and not knowing it's construction. But such as it is, still in the hunt for an RV4, and again thanks for the info Never know when I might be back asking for more!!
