Go Back   VAF Forums > Main > Safety
Old 10-28-2014, 11:56 PM
SMO's Avatar
SMO SMO is offline
Default What does the inside of YOUR oil separator look like?
I have a Christen system I removed from my 1987 RV-4. I don't know how long it was on there. I took it off soon after I got the plane in 2007, and it has been sitting around my shop ever since.
I was going to put this up for sale and thought I would remove the fittings for transport. Turned out the middle fitting on the separator had been cross threaded so that part is now junk.
I took off the bottom fitting and this is what I found:
Decided to cut the bottom off the can. This is what the bottom looks like on the inside (the silver speckles are from cutting it open):
Here is a shot of the whole thing:
Anybody want to buy my system (minus the separator and the middle fitting)?
Mark Olson
1987 RV-4 Sold
2003 Super Decathlon - Sold
F1 EVO Rocket, first flight May 31/14
First in line for the Sonex JSX-2T kit
Old 10-29-2014, 07:52 AM
RKellogg RKellogg is offline
Arrow What exactly are we separating... ??
Most interesting, Mark!
I had installed a separator on my RV, but removed it before first flight, based on feedback from a respected graybeard. His theory was that the separator returns condensed water vapor to the crankcase along with the scavanged oil, creating more acids and corrosion-enhancing compounds in the oil. Tribological chemistry is beyond my paygrade, but it sounds reasonable. It would be insightful to compare oil analysis from engine with and without oil separator, maybe before and after... Maybe the amount of crud that the separator returns to the case is so small compared to the amount generated as to be a non-issue.
I like a clean belly, but also want to get to TBO. Anyone have real data that transcends hearsay?
- Roger
Old 10-29-2014, 08:29 AM
DanH's Avatar
DanH DanH is offline
Yeah, oil analysis. "Water return" is mostly BS.
Dan Horton
RV-8 SS
Barrett IO-390
Old 10-29-2014, 09:11 AM
Tom Martin Tom Martin is offline
I had made a separator for my rocket and ran with it for a couple of oil changes.
Rather then returning the bypass to the crankcase I collected it in a coiled tube below the separator and then drained that off occasionally to see what was there.
It was pure oil, no sediment, no water, no crud.
Currently my breather vent exists parallel to the floor of the fuselage about 2" aft of the cowling. It has been like this for a few years. At the time I installed it I had a negative 2"Hg. I have not checked the pressure/vacuum since that time but with 850 hours on the engine I have NO drips in the cowling. I do have a nice clean line of oil on the belly, that gets wiped down with each 25 hour oil change.
Tom Martin RV1 pilot 4.6hours!
CPL & IFR rated
EVO F1 Rocket 1000 hours,
2010 SARL Rocket 100 race, average speed of 238.6 knots/274.6mph
RV4, RV7, RV10, two HRIIs and five F1 Rockets
RV14 Tail dragger
Fairlea Field
St.Thomas, Ontario Canada, CYQS
fairleafield@gmail.com
Old 10-29-2014, 10:26 AM
SMO's Avatar
SMO SMO is offline
I was not surprised to see this. Maybe it is something specific to the Christen system. The owners manual for my Decathlon said to drain the Separator's bottom hose at each oil change.
I did this at each 25 hour oil change and always found water mixed with oil coming out the separator and hose.
Mark Olson
1987 RV-4 Sold
Old 10-29-2014, 12:46 PM
Smilin' Jack Smilin' Jack is offline
I have to agree with Dan,
that's one reason it is important that your oil temp is not too cool......
Smilin' Jack
Smilin' Jack & Anita Hunt
N507H RV7, KJZP Jasper, GA
EAA690
APRS/ WB4JKY
Retired Corporate Pilot CFI-AI, MEL
CE500, LRJT, HS25, C650, SBJT, CL60
Hunt Aviation, LLC.
Pilot Service, IPC's Biennials.
Comm Glider
Old 10-29-2014, 02:32 PM
AlexPeterson's Avatar
The system looks like it rarely, if ever, saw inverted use. I used to exercise mine frequently. I didn't re-install it after an overhaul, because it got to be that the only inverted I did was to exercise the system! It looked good inside after 10 years and 1200 hours.
Alex Peterson
RV6A N66AP 1750+ hours
KADC, Wadena, MN
Old 10-29-2014, 06:53 PM
BCP Boys's Avatar
BCP Boys BCP Boys is offline
Smilin' Jack
What is considered "too cool" ?
Amir
RV-7 - Regretfully Sold (Currently in therapy )
RV-10 - Sold
Supporting VAF since the first visit
Old 10-29-2014, 07:37 PM
BruceEicher's Avatar
BruceEicher BruceEicher is offline
And as reported by the OP the pot sat 7 years after removed from service till cut open recently. Right?
Bruce, Katie, Hana and RV-8 HulaGirl
Old 10-29-2014, 10:51 PM
AK4x4's Avatar
AK4x4 AK4x4 is offline
Default To Cool
An oil temp that does not reach 212 degrees at the hottest point in the engine is "too cool" this temp will boil the water (and assorted other bad things) into vapor so they can go out the breather. It is generally accepted that a gauge indication of 180 degrees corresponds to 212 ish degrees at the hottest point inside the engine. I recommend that the engine be setup to operate between 180 and 200 on the gauge. Good luck, Russ
Russell Brown
A&P/IA
"Happiness may never be sensibly pursued as an end in itself, because happiness is the by-product of achievement." -- Northcote Parkinson (paraphrase)
Wasilla, Alaska
