10-25-2014, 08:18 AM
Beginner Electrical Question
I am building a -14 and and am installing a Garmin GAP-26 heated pitot.
I need to connect up the wires from the control box to wires leading into the fuselage.
there are 2 black 16 gauge wires and 2 red 16 gauge wires. the black wires need to be connected to a 14 gauge wire. the reds as well. what is the best way to do this? terminal fasten clip and fasten tab? crimp all there wires together? butt splice? Or is there a better method.
Also, where is the best place to get electrical stuff? Stienar?
thanks
ken
Ken Stockman
Midland, MI
EAA Chapter 1093 member
FaceBook Page: Ken's RV-14
RV-14a (serial number 140073)
N73XP
Plane at hangar and the wings ON.
10-25-2014, 10:13 AM
You can connect wires like this in any of several ways. - Splice and solder, with heat shrink tubing over the joints.
- Use a round butt splice connector
- Use mating pairs of Faston tabs & receptacles with heat shrink over the joints.
- Use some other crimped pin connector, like a Molex.
It depends on whether you ever expect to need or want to disconnect it. If you do, go with a connector. If you don't, a decent mechanical connection soldered and insulated would be fine. Faston or butt splice would probably be my choice over a soldered splice, just because of Murphy's Law. In my experience, soldering will guarantee you have to take it apart for something. Using a pluggable splice probably means you will never have to touch it again!
I haven't bought anything from Steinair, but people speak highly of them. When I'm buying generic electrical or electronic bits and pieces, I usually buy from my regular suppliers if they have what I need at a decent price. But, I order from Mouser and Digikey at least every couple of weeks. Neither of those are a good source for wire in the quantities we need, especially Tefzel insulated wire. The wire is best sourced from an aircraft supplier; connectors and heat shrink are not aircraft-specific and can come from anywhere.
Dale
Omaha, NE
Previous RV-7 project (sold)
10-25-2014, 10:16 AM
Butt splice sounds good but even at that you will need the proper aviation grade hardware and correct crimper. If you're just getting started and don't have that stuff then look into something like this. http://www.steinair.com/storedetail.cfm?productid=478
No doubt you will spend this much anyway.
Derek Hoeschen
EAA Tech Counselor
RV-9A #92103 - N803DK
G3X, Superior XO-320, Dual Pmags, Catto 3B
www.mykitlog.com/dbro172/
1974 Bellanca Super Viking - N16AW - Flying
RV-8 #83565 - N184DK - building
1968 Mooney M20C - N6801N - Sold
1956 C-182 - N744W - Sold
10-25-2014, 10:18 AM
Simple
Stein is a one stop shop for avionics, electrical, advice and hands down the absolute best Customer support. You won't be disappointed. Call them and they will take good care of you.
Charlie Hammes
RV-8, N525RV Flying
RV-8, N208CH in process
10-25-2014, 11:05 AM
Senior Curmudgeon
I have had good luck using these.
Stein has them, http://www.steinair.com/storedetail.cfm?productid=343
Use good crimpers, ( like these from Stein) and put heat shrink over the connector, all the way past the insulation and onto the wire a half inch or so. If you have more that one wire as you mention, tie the wires together for support, less stress on the crimp joints.
If you ever need to take the connection apart, just simply slice off the heat shrink and unhook the connectors.
By the way, for small sized wiring I like Deans connectors or simply use the pins from D sub connectors pins without the shell, and heat shrink over them.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
10-25-2014, 11:31 AM
I already purchase the crimpers for terminals and molex connectors from Stein. I think that I will give Stein a call to see if they can put something together for me. I am not sure that their generic box of connectors is what I need.
It does seem like Stein does have a nice box of heat shrink to get started with.
So any connector should have heat shrink over them? Just to ensure they don't come apart and that no wire to wire shorts occur.
Mike S--how do those connectors work? I saw them on the stein site, but was not sure how they works.
thanks
ken
Ken Stockman
Midland, MI
N73XP
10-25-2014, 12:09 PM
Senior Curmudgeon
thanks
ken
Very well
Take a close look at them, there is a straight portion close to the insulation, and the end has a part folded over. There is only one ----unisex---of them, not a male and female like most connectors. The fit together like a handshake, or a gladhand air coupling. The folded over part grasps the straight shank.
Yes. Exceptions like D sub, Molex etc.
Mike Starkey
VAF 909
Rv-10, N210LM.
10-25-2014, 01:51 PM
that is how I thought that they went together, but wanted to make sure.
thanks for the pictures
Ken Stockman
Midland, MI
N73XP
10-25-2014, 01:57 PM
Senior Curmudgeon
Dont thank me, thank Mr. Google
Mike Starkey
VAF 909
Rv-10, N210LM.
10-28-2014, 12:16 PM
So true! I like to use soldered connections with heat shrink, but always leave enough slack to cut and redo a few times.
Doug
RV-9A "slider"
Tail number N427DK
Donation made for 2020
