Old 10-24-2014, 02:58 PM
Bavafa Bavafa is offline
Originally Posted by Mel View Post
If you have a constant speed prop, you might check it as well. They often will spit oil droplets.
Ditto that. For a short period of time, I was seeing a very small streak of oil on the top of my cowl, starting on the top of the right air inlet. I searched and searched and could not find any oil leak within the engine that could come out that way. I looked at my prop and saw evidence of oil/grease or whatever it was on the back side of the prop and inside the spinner. I took the zerk off which I heard a hissing sound as air was exiting or entering since then, I have not seen this.
My theory is that a bit of grease was coming out of the seals and melting due to the hot cowl.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 10-24-2014, 03:14 PM
Low Pass's Avatar
Low Pass Low Pass is offline
Originally Posted by jbDC9 View Post
I had one of these pesky leaks on my RV-8 as well, an annoying oil mist/small droplets on the windshield, a bit heavier on the right side. I thought it was the front crank seal and replaced it twice to no avail... I tried U/V dye in the oil with a black light but it didn't seem to pinpoint it. Finally I tried the technique of dry spray foot powder; I sprayed some on the upper nose case at the CS prop governor oil line elbow. A-ha! The powder was wet! I put a wrench to the elbow and it was barely tight; methinks the engine assembly shop didn't tighten it and I didn't catch it. I put in a new elbow snugged in tight, that seemed to fix it.
Been there, done that. Careful twisting down too tight on the pipe elbow. The casing is an aluminum casting after all. I cleaned, "lightly" torqued, and Prosealed mine in. No leak.
Old 10-24-2014, 03:24 PM
BillL BillL is offline
If I re-read the OP enough it was asking basically how the oil got out to the windscreen. If that is the question, some work that DanH has referenced in his shrinking exit thread referred to air in the lower cowling being drawn through the space at the back of the spinner and discharged externally. Some even recirculates into the inlets. With his higher pressure lower cowl, he even sealed the shaft/cowl with a rubber seal.
This is how it might get out, but many comments here about where it originates.
Bill
RV-7
Lord Kelvin:
Old 10-24-2014, 06:55 PM
rzbill's Avatar
rzbill rzbill is offline
In the initial few hrs of our trip to the canyons, a discoloration streak appeared on the top cowl, from the right inlet, next to the spinner. There was not really enough to wipe off. Just discoloration of the primer on my cowl.
I took the top cowl off. Everything appeared dry as a bone. I've seen prop grease emanations on an Arrow before. My prop is dry as far as I can tell. No streaks.
It grew enough to lightly spatter the passenger side windshield.
Cleaned the cowl and canopy. Next flight got a slight wisp on the canopy. Cleaned it. The total time from start to finish was roughly 4 flight hrs. Been good for the next 20 hrs. The stain on the cowl is still there but it is dry to the touch. The canopy is not getting any spatter that I notice anymore.
Dunno'. I'm still guessing a burp of prop grease because the canopy looked the same as the Arrows did.
BillL,
I wondered about inlet backflow next to the spinner and for some short time thought this was oil coming out my alternator blast tube (I have a slight seep at the front of the oil pan so oil is available) because this tube inlet is pointed at the right spot on the cowl. BUT, the inside of the blow tube feels dry.
On an Occams razor side note, this 4 hr event was after the plane sat outside overnight in a rain storm from hades. First time. She's a hangar babe. I wonder if the high winds and rain moved some oil or grease inside the cowl to a new place?
Bill Pendergrass
ME/AE '82
Old 10-25-2014, 08:03 AM
bpattonsoa bpattonsoa is offline
I had oil on the passenger side of my -10 for the first few flights. Very light, but reappeared after every flight. Ship has the AntiSplat oil separator with vacuum and there was (and is to date) not a sign of any oil leak. Fingers crossed!
Someone asked how many times I cycled the prop on runup a and the answer was two or three. He recommended just once and the oil went away after a couple more flights. Never saw a clear sign of a leak on the hub.
Bruce Patton
Rans S-20 Raven 796S flying since 2019 (slowly)
RV-6A 596S flying since '99 (Sold)
HP-18 5596S flying since '89
RV-10 996S flying since 2014, quick build wing and slow build fues., - dual Skyviews with complete system, two radio and not much else. Interior completely finished with Zolatone. CF plenum. 1624 lbs, FLYING after a 21.5 month build.
