Old 10-23-2014, 07:37 PM
Default Cheap Weight Savings
See the small tab on the rod-end bearing? Normally, we use an AN970 washer. But there's really no need to carry that much weight around, so I made a few of these from .025 aluminum. Plenty strong enough and saved enough grams to justify the small effort.
For more weight savings, the thin washer and the MS21042 nuts help out. Even on my RV-3B, changing to the MS21042 nuts saves a whole pound.
Of course these things were part of installing my autopilot roll servo and that's over four pounds added. Some days are like that.
Dave
Old 10-23-2014, 08:25 PM
gasman gasman is offline
Yep..... It even makes it easier to lube the bearing.
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
