Old 10-23-2014, 01:16 PM
wera710's Avatar
wera710 wera710 is offline
Default Sunrise over the Bay
Sunrise over Easton MD. RedStar Formation Clinic.
https://fbcdn-sphotos-d-a.akamaihd.n...5afdd8c850fc38
The red aircraft is an F-22. Decendent of the Falco and SF-260. Only one in the US. My buddy Dan is at the controls.
https://fbcdn-sphotos-e-a.akamaihd.n...3e4430d365df8f
Hopefully the images will post. If not, let me know.
Scott "Lawbreaker" (yeah, its a fair cop!)
RV-8 N710PX "Bad Attitude!"
Old 10-23-2014, 06:50 PM
panhandler1956's Avatar
Nice pic!
Is that a salvo pod under your right wing?
Brent Owens
Columbus, OH
RV-8 'Contrary Mary' flying
N784DE S/N #82614
www.fixedwingbuddha.com
Follow me on Facebook
Old 10-24-2014, 08:27 AM
Capflyer's Avatar
Capflyer Capflyer is offline
You mean something like this? Let the guessing begin!
Mike
RV4/HRII Hybrid - Building
RV8 Hot Rod "Drone Killer" - Flying
RV8 Blue Nose "Look'n Good" - Flying
RV4 - FAST & FUN! Rebuilt, Flown, Sold
RV-7A Built, Flown, Sold
Old 10-24-2014, 09:19 AM
wera710's Avatar
Yup. CDU-Mk1. For dispensing rubber chickens, flour "bombs", or TP. Got tired of not being able to compete in various fly-in competitions due to the inability to open the canopy in flight. Well, you can, but it takes both hands if you are trying to hold it open and drop a rubber chicken on a target! This solved the problem. Chef (aka Capflyer), naturally, decided that if one is good, two is better. Cheating ***tard. ;-)
Old 10-24-2014, 09:58 AM
Capflyer's Avatar
More is always better, whether ordinance or women! Mine is code named the "Pappy Parker".
And, everyone should be happy to know that the RV's kicked the war birds butts this year. Mugsy had a direct hit on the target and won this year, first time for the RV's. Their event and they were not happy. Next year will be even more of a blast now that the rivalry is building.
Mike
Old 10-24-2014, 10:14 AM
Mugsy's Avatar
Mugsy Mugsy is offline
Default AGM-65 KFC Poultry Launcher
I have been negligent in posting this information sooner but this seems like an appropriate time. Below is a link to detailed photos on building my version of the AGM-65 KFC Poultry launcher which successfully flew its first sorties last year prior to the Easton, MD World Famous Chicken Drop.
I am also happy to report that great fame and notoriety has been bestowed upon our RV brethren as a result of winning 1st place in this years event. My winning drop was about 9 feet from ground zero (the local airport truck). We were up against a formidable fleet of Red Star pilots and aircraft (Yaks, CJ-6s , T34s and AT-6s). This is the first time their group has been dislodged from the winners podium and they were quite 'surly' as a result. But hey, its all in fun and we had a great time. Both Chef and Lawbreaker have great designs also. However, the use of 'dual' pods is in violation of various firearms regulations in several states HI HI !
Perhaps we can grow this into more of a nationwide activity with more innovation sure to come. Give it a try. There is nothing like hitting that 'Pickle' button as you launch that bird!
Mugsy
https://plus.google.com/photos/11218...CNf6mYalw8iDOA
Here is an exert from an earlier email sent to our local Dragon Flight
Attached are multiple photos detailing the construction of the KFC AGM-65 Chicken launcher. This is designed for standard size rubber chickens. These are approximately 23" long and 5" wide. This size chicken will be issued to you at the ESN Airport Day for the drop. The use of other chicken sizes may or may not work with this launcher. Smaller chickens have been known to slip out, especially those scrawny little Italian chickens!
The aluminum flashing can be bought at Home Depot etc and is normally 24" wide. All of the wood is either 1/2" soft pine, 1/4' plywood, or a small piece of hard maple for the trigger block.
The launch tube aluminum is overlapped 1/2" on the top and riveted (pop rivets) about every 2 1/2 to 3". A 2" size piece of fiberglass cloth is lay ed down the length of the tube over top of the rivets. Make the nose bowl out of a solid piece of pine. Cut with a jig saw and relieve the inside edge to fit inside the front of the launch tube (see photos). I used West System epoxy for all attachments and fiberglass work. A hot glue gun can be used to tack a part into place before final epoxy/fiber glassing into place. This is helpful especially with the fins. The 2" ID PVC pipe MUST be reinforced with at least 5 layers of fiberglass cloth where it attached to the launch tube and the main flange !!! Sand the PVC pipe before fiber glassing.
The release latch motor is a standard 12 volt car door lock mechanism which can be obtained on Ebay / Amazon for under $10. A piece of hinge wire runs from the latch motor to the release block. The trip wire is made from 14 or 16 gauge wire. It attaches to the bottom of the launch tube and has a loop on the other end (soldered). Strip the insulation off the ends if you use electrical wire. This loop is what fits into the maple release block. Make sure the loop can move in and out of the maple block without binding. The wire fits under the chicken's crotch when loaded in the launch tube.
A pair of wires will run from inside your wing (either side is OK), to the cockpit. My launcher is mounted on the center inspection plate. You will need access to 12 Volts, normally via an accessory outlet. Your master release switch should be a momentary contact type button wired in series with an ARM switch so that you don't get excited or forget and bomb a school bus or something known to make the headlines! RadioShack is a good source for the project type box and switches.
Mugsy
Old 10-24-2014, 10:48 AM
colojo's Avatar
colojo colojo is offline
That sunrise photo absolutely rocks!
Joe Zuffoletto
RV-8 (flying)
Fullerton, CA (KFUL)
2021 dues paid!
Old 10-24-2014, 11:42 AM
xavierm xavierm is offline
Default Got me curious
The link to the build pictures didn't work for me.
Sounds like a lot of fun though!
_____________
Xavier
RV-7 build in progress
www.theaviatorx.com
"Genius is persistence in disguise"
Old 10-24-2014, 11:55 AM
Stitch462's Avatar
Stitch462 Stitch462 is offline
Link not working for me either. Interesting project, did the exact type of work for Uncle Sam for 24 years but when our stuff left the airplane it made a bigger boom and tended to put real damper on the bad guys weekend. So is the chicken ejected out somehow i.e. spring pressure, rocket motor or just sucked out into the slipstream once you hit the pickle button? Lastly, how do you aim? What about...? How do you...? Wow, this project could turn into a whole thread all by itself!
Stitch
MSgt, USAF, Ret.
RV-8 Dreamer
Old 10-24-2014, 01:24 PM
Mugsy's Avatar
Default Updated link
Here is an updated link to the design photos of the AGM-65 KFC launcher.
Let me know if you can't access.
Also, here is a link to a video from last years event
https://www.youtube.com/watch?v=9jYVn8WwYZk
Mugsy
