Old 10-20-2014, 10:23 AM
RVG8tor's Avatar
RVG8tor RVG8tor is offline
Default Gray soot by lower baffle
I still need to go pull the cowl, I usually inspect the underside of the engine after flight through the lower cowl with a flashlight. I have noticed some gray soot at cylinder fins at the edge of the aft lower baffle. My guess is this is some sort of accumulation of dust.
I just wanted to know if others have seen this before, I can't see the other lower baffles without pulling the cowl. Picture late today but any info before I head to the airport would be helpful
Cheers
Mike "Nemo" Elliott
RV-8A (First Flight 12-12-12!)
KOCF
N800ME
www.mykitlog.com/rvg8tor
Dues Paid 2019
Old 10-20-2014, 10:37 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Could be your baffling is vibrating, and causing this. When two pieces of alum work together they make a residue that looks like black soot. Look for a shiny spot in the middle of the sooty area.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
