Old 10-20-2014, 07:18 AM
Robert M's Avatar
Robert M Robert M is offline
Default Crankcase bolt type for O320-A2B
Hi guys!
I am in the process of accumulating all the hardware necessary to put my engine back together again, specifically the crankcase. In the Lycoming Parts Catalog PC-103, in figure 1-5, Standard Crankcase, Crankcase Attaching Parts, Reference # 6, STD-1416. I can't seem to find that particular bolt at any of my favorite shopping locations based on the number given.
Since these bolts are covered by the oil sump and inaccessible from the outside, I'm guessing they are drilled shank bolts (doesn't say in catalog).
These STD-1416 bolts are 1/4" x 20 x 1 1/2". I believe a replacement for these would be AN4-14. Although the AN4-14 are 1/4" x 24 X 1 1/2", I believe they will work but would require a 24 thread castle nut.
Anybody know if the AN4-14 would be a correct replacement?
Thanks.
"Pilots: Looking down on people since 1903"
(author unknown)
RV-9, N556RM, O-320, Dual PMags, Catto 3 blade.
FLYING since 2018
Mosquito XEL ready for flight
Old 10-20-2014, 08:02 AM
krw5927 krw5927 is offline
Looks like part number LW25S1.50 has replaced the STD-1416 bolt. Try a search for that. Some in stock here:
http://www.cessnadirect.com/lw25s1-50.html
Superior has part number SL25S-1.50, which is a PMA approved replacement for both the LW25S1.50 and STD-1416:
http://www.superiorairparts.com/down...SL25S-1.50.pdf
An AN4 bolt will have 1/4-28 fine threads. One reason you wouldn't want to use these here is the torque requirement. You would have a very different pre-load on the bolt if you torqued a fine-thread bolt/nut to the same value as a coarse thread bolt/nut. Another is the thread length and shank length dimensions. Without a drawing of the Lycoming bolt there's really no telling whether the dimensions of an AN bolt are even close. You may get the overall length right, but you may end up with threads taking a bearing load or other undesirable configuration.
Kurt W.
RV9A
FLYING!!!
Old 10-20-2014, 08:55 AM
659JR 659JR is offline
Default hardware kit
I just ordered in a couple of ECI hardware kits for the engine assembly. I have not used one to assemble yet but looks pretty complete.
Jesse
970-874-7575
Old 10-20-2014, 11:34 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
This might help decode replacement part numbers -
http://nebula.wsimg.com/670c250fc9d9...&alloworigin=1
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 10-20-2014, 12:50 PM
jrs14855 jrs14855 is offline
Default Bolts
Dart Aircraft in Waco TX is very helpful in sorting out part number changes. They sell Superior, ECI and Lycoming parts. Excellent service.
I believe there is a change in the torque specs for the 1/4" case bolts, can't remember where I found that.
Old 10-20-2014, 03:24 PM
scsmith scsmith is offline
Default l'll bet ya....
When you get the right bolt from lycoming or other supplier, I bet you find that it is an SAE Grade 8 bolt.
Someone please tell me if I'm wrong.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
Old 10-20-2014, 04:04 PM
You may be right, but are you willing to bet your engine (or at least the hassle of dropping the sump to fix) on it in order to save less than $20?
Kurt W.
RV9A
FLYING!!!
Old 10-25-2014, 10:23 AM
lr172 lr172 is offline
I just rebuilt my o-320. The case bolts are just standard bolts. They were not Grade 8 and not even Grade 5. The 1/4" perimeter bolt don't really hold the case together, just the edges for sealing and rigidity. In my case, the three bolts in the sump area were the same 1/4-20 standard bolts but were drilled and used castle nuts. I presume this is because loose bolts cannot be identified during inspections.
Larry
Hi guys!
Thanks.
Old 10-25-2014, 12:30 PM
Default Bolts
Larry
They may very well be the equivalent strength of "just standard bolts" which would imply hardware store bolts. Hardware store bolts are only available in 1/4" length increments. Some of the Lycoming bolts are 1/8" INCREMENTS. Lycoming bolts are cadmium plated, hardware store are usually not cadmium.
Old 10-25-2014, 12:51 PM
flyingriki's Avatar
flyingriki flyingriki is offline
If you do as much research as I did when building mine you'd find the spec for Lycoming engine bolts is exactly what you suggest. A very experienced engine builder confirmed this and pointed me to the most economical source.
But, as also pointed out, the 1/8" increments mean you'll use a few longer ones but the difference between $2 and .20 times all the case bolts is substantial. It's one thing to be cautious when not knowing any better, a good idea, but with enough information there are options. Looks like your qualifications put you in the latter group!
