Old 10-16-2014, 09:29 AM
flybill7 flybill7 is offline
Default 2X No Problem
I used a 2X for the entire project and the plane is still holding together after 875 hours. I'm not saying its better than the 3X or 4X but it will do the job.
Bill Cloughley
Severna Park, Maryland
RV-7 Flying (1,400 hours)
http://www.pilotbill.com
Old 10-19-2014, 04:07 AM
bobnoffs bobnoffs is offline
thanks to all that replied.
i picked up a used 3x gun from vans classifieds. not sure about a tungsten bar will use a few hand me downs for now.
i am reinforcing a few places as i am going to use a viking in my 12. solid rivets in a few places at the least make me feel better and i want to learn to buck rivets.
the viking is 35-40 lbs heavier than the 912.
Bob Noffs
n. wi.
dakota hawk/jab 3300 built and flying. sold 6/18.getting serious about the 12. in the hangar now as of 10/15/19
RV-12 kit as of 9/13
Old 10-19-2014, 05:37 AM
Walt's Avatar
Walt Walt is offline
I use a Cleco 2X gun exclusively for the "small" stuff. This is a high quality gun that can easily drive 1/8 rivets at 95psi, turn the pressure down to 45-50 psi and its perfect for 3/32 rivets.
Bottom line, I prefer a good 2X for RV type work, its also smaller and easier to work with than the larger guns.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 10-19-2014, 10:27 AM
David Z David Z is offline
Default Physical Dimensions
2x guns are shorter and will fit into tighter locations.
RV-8
Empennage Passed Pre-close Inspection
Wings mostly done
Fuselage is "in the mail"
83126
Dash 8 day job is financing the RV-8
Donation till September 2021
Old 10-19-2014, 10:44 AM
gasman gasman is offline
Since you said the project you are considering is 95% 1/8 rivets, my recommendation would be for at least a 3X.
My preference is a 2X for 3/32 rivets put you will have so few it probably wouldn't matter.
The bucking bar that is my favorite is no longer available so I can't recommend anything, but for 1/8 rivets stick with bars on the heavier side.
Thinking about building a T18?
Scott, Can you show us a picture of it?
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
