Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Glass Cockpit
  #11
Old 06-15-2017, 05:41 AM
Walt's Avatar
Walt Walt is offline
Originally Posted by jliltd View Post
Can an external dimmer control attached to the GTN lighting circuit be a PWM type or does it have to be a legacy type rheostat? Or either?
Jim
The dimmer input specifies a voltage input, PWM won't do it.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 07-02-2017, 11:59 AM
jimbo jimbo is offline
Default What dimmer to use if not pwm?
Originally Posted by Walt View Post
That's why I always install a dimmer pot!
What dimmer do you recommend Walt?
Thanks for sharing!
Old 07-02-2017, 05:29 PM
Walt's Avatar
I just use a small high quality 10K pot like this one:
PN: RV6NAYSD103A
Old 07-03-2017, 10:55 AM
PN: RV6NAYSD103A
https://www.digikey.com/product-deta...103C-ND/222834
Knob selection is below item description
